Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. sdroadster
    sdroadster
    I understand. I have seen the U shaped end of a front wishbone used on a rear bone application. Use 2 lower rubber ball cups sandwiched, and bolted to a cross member, then you can use the stock rubber wishbone ball like factory.
    33Doll likes this.
  2. 33Doll
    33Doll
    Thanks, that’s different. They also seem to work fine split about 6” apart also.
    I will probably go that route. Or maybe get a Pete&jakes Kit
    Stogy likes this.
  3. 33Doll
    33Doll
  4. 33Doll
    33Doll
    We’ve been coming into work one day a week each one of us so we’re separated, dure to COV-19
    To day I showed up, and this was on my desk! My buddy has been doing a little wood work for me!
    Awesome Job! Thanks Jim!
    He did such a good job, I’m gonna have him do the Small A- pillar pieces!
  5. 33Doll
    33Doll
    Fits perfect! Just sitting there for now, gotta a lot of work before that puppy goes in permanent-like!
  6. 33Doll
    33Doll
    Working on this side of the car I got hungry all of a sudden.....
    and wanted a sandwich!
    With a lot of Swiss cheese LOL! This side is going to be a lot of fun!
    tb33anda3rd, Stogy, dwollam and 2 others like this.
  7. 33Doll
    33Doll
    Hey Dirk35
    I did your method, to stretch the metal, in addition to the way I formed it on the vice last time. It turned out even better this time! The wheel well was more Swiss cheese than the last one and I’m actually filling this one quicker, I’m almost done already!
    Also I can’t remember who told me about the thinner wire but I got some more.025 this time, and it works so much better than .030! Moving right along!
  8. 33Doll
    33Doll
  9. 33Doll
    33Doll
    Dag Nabit!
    Ran out of Welding Gas... again!
    I’ve always only needed the little short bottle! So it fits under the work bench! Might Need a big one for this Job!
    Oh well, Im almost done with the major welding stuff anyway, no reason to change sizes now! Get S’more Mañana!
    thanks Guys for the suggestions! I listened to 1 or 2! Lol!
    tb33anda3rd, Stogy, brEad and 4 others like this.
  10. 33Doll
    33Doll
    Welp! The wheel tub, upper and lower is done! This side looks better than the other side! And I was having a hell of time getting a clean weld/ground or something! It getting black soot. New gas too! Oh well turned out good! I am Happy!
    IMG_9312.JPG IMG_9313.JPG IMG_9314.JPG IMG_9315.JPG IMG_9316.JPG IMG_9318.JPG
  11. Great progress and nice work, I have similar rust in the same places on my 34 Tudor, its great to see what I am going to be up against.
    Stogy, 33Doll and loudbang like this.
  12. Pewsplace
    Pewsplace
    Great thread and work on your tudor. Mine was rust free and saved me lots of work. Yours will be really nice after getting the meatal replaced. They make nice rides.
  13. 33Doll
    33Doll
    Thanks Guys!
    So... I like to do before and after pics at the end of each section I do, in addition to the The regular documentation I do during each segment. Kind of a progress report kind of deal to make me feel better I guess. Little stepping stones to keep me motivated??
    Hope you enjoy these little tidbits!
    Passenger wheel tub, before and after;
  14. 33Doll
    33Doll
    More Done!
    This aftermarket patch doesn’t fit as nice, so it needed tweaking!
    IMG_9321.JPG IMG_9322.JPG IMG_9325.JPG IMG_9326.JPG IMG_9332.JPG IMG_9330.JPG IMG_9331.JPG IMG_9329.JPG
  15. sliceddeuce
    sliceddeuce
    I approve. Carry on.
    33Doll likes this.
  16. You’re doing a really nice job! Cool car with a great story.
    Stogy, loudbang and 33Doll like this.
  17. 33Doll
    33Doll
    Thanks! These aftermarket patch panels fit pretty good, but they are slightly off, and the back corner is a little to 90-ish, and should have a little more of a radius, so the fender and the running boards are gonna fit real tight there. but it’ll fit. I could slice and dice and pie cut the bottom in the corner but I don’t think I want to mess with all that! nobody’s going to be looking in the dark corner, once the fenders and running boards are on.
    Once there are fat tires on the back and loud pipes nobody will notice!
  18. 33Doll
    33Doll
    This side is going alot quicker! Even with some fitment issues with the aftermarket market patch! I modified it a bit, you cant really see it, but the bottom corner where the fender, and running board meets the corner, was stamped a little too much 90* degree/squared off, so I cut the inside edge off, and pie cut the bottom in 3 or 4 places and hammered it in, and under, to fit my homemade inner curved piece, and BAM! Fixed it!
    I formed the curved piece, in stages, to go from a wide radius at the top, to a sharp 90* at the bottom so the inside mounting flange of the fender will pull in tight to the corner, If that makes sense???
  19. jimmysweden
    jimmysweden
    from sweden
    Looks great. Keep on welding..
  20. 33Doll
    33Doll
    Yeah, the fender fits way better in the inside corner also! Had to much radius on the other side, I tweaked it, so it is fine. But this one is NICE! (Back Pat!)
  21. 33Doll
    33Doll
    Got alot More Done!
    Should be done with the Passenger side also soon, Monday, or Tuesday...
    Taking weekend off!
    Hey Dirk35! I curved the Piece on this rocker like you said! Way more radius this time! The Cowl will be easy!
    Adjustments.JPG IMG_9383.JPG IMG_9389.JPG IMG_9387.JPG IMG_9385.JPG IMG_9394.JPG IMG_9395.JPG IMG_9396.JPG IMG_9393.JPG
  22. 33Doll
    33Doll
    Almost done with The Metal work!
    Finish weld, Dolly and hammer the Skin patch a bit, and replace the inside cowl foot section like the driver side I did.
    YAAY! Corona Isolation!
    ( For me anyway)
    Works gonna start again in a week or 2 I’m thinking.
    Thats good for the out of work people
    Though.
    IMG_9402.JPG IMG_9408.JPG IMG_9411.JPG IMG_9412.JPG IMG_9415.JPG IMG_9416.JPG
  23. Your skills continue to improve. Very nicely done!
  24. 33Doll
    33Doll
    I almost Made It Just the Cowl Foot Left! And I am done with the metal Replacement!
    More before and after:
    IMG_8364.JPG IMG_9425.JPG IMG_8449.JPG IMG_9424.JPG IMG_8750.JPG IMG_9431.JPG IMG_8733.JPG IMG_9429.JPG IMG_8853.JPG IMG_8873.JPG IMG_9162.JPG IMG_9248.JPG Adjustments.JPG IMG_9403.JPG IMG_9412.JPG IMG_9415.JPG IMG_9437.JPG
  25. I'd have that rectangular chunk of frame rail framed and on my shop wall! Don't stop now, you'll never start again! Nice work.
  26. 33Doll
    33Doll
    Thats What my Pops said!
    I’m gonna finish Monday
    Thanks!
  27. dumprat
    dumprat
    from b.c.
    Looking good!
    I would steer away from any aftermarket suspension parts, just some minor corrections to what your dad did.
    I would pie cut your rear radius rods and bend them towards the middle and reuse the original frame mounts in the middle.
    I am also a fan of the build it like they did back in the day rather than the spend millions and never get it done. Spray bombs, brush paint, patch panels and rust converter for the win!
    Well done!
    brEad, dwollam and 33Doll like this.
  28. 33Doll
    33Doll
    Yup! You think like me, I am probably gonna do that, I don’t really like the way they are mounted now. It won’t cost anything, take a few hours, boxing the cross member, and fabbing a cross brace with a jog around the drive shaft, probably some square tubing. Weld the existing mounts to the bottom of it.
    It’s just a little old 85-90 horse Flathead, maybe 100 with the 4 barrel and electronic distributor. it’s not gonna break anything
    I do like the nostalgia aspect of how my dad did it, but he did do some questionable things that I’m going to correct/improve. Even he agrees on sone of it. Thanks
  29. dumprat
    dumprat
    from b.c.
    Glad your dad approves!
    I especially like the old pic of the car full of irrigation pipe. Hot rods were built to be used and driven. Not hidden away and pampered.
    33Doll likes this.
  30. 33Doll
    33Doll
