Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. 33Doll
    33Doll
    First one going ok! Dang metal is so thin! Using a piece of Brass behind where I can reach! Oh-Well... can always patch in more, if it doesn’t work! Adjustments.JPG
  2. sdroadster
    sdroadster
    Besides turning your Mig welder down low, you can go to a smaller diameter wire. I use .023 for sheet metal. It melts faster, and you will have less burn through on thin metal. .032 is for frame work, and cross members, where you need higher heat and penetration..
  3. 33Doll
    33Doll
    Welp! Took 4 hours But One hole is done! Found a piece of aluminum and a big magnet to hold it down behind it, and cranked the heat way down!
    Cant afford smaller wire and tips right now, spent a bunch on gas! Got use what I got, at this point, no extra money in the Hotrod budget! Gotta use my Brain to make it work!.... ouch... I’ve got a headache! The upper hole is gonna be fun!
    Its ugly on the back side, but who cares, under coating will take care of that! I used 16g to make it stronger, and save the little bit of 19g I have for the body! Its a home built poor mans hotrod! Cant get more Traditional than that! My Pops did in alleys back in the day!
    (I got a little Jealous when I read Pat Ganahals 33’ build...nice!)
  4. 33Doll
    33Doll
    Its a 1969 Shelby GT 350, he is selling it too. Its Real.
  5. 33Doll
    33Doll
    Now that Im getting some practice, the patches are looking alot better! Had to add another hole though! Keep finding hidden holes when I clean off the crud with the wire wheel. So a total of 5 on the upper wheel well. 2 to go then I can work on the lower section. Which should be easier!
    Man! these small holes are tedious, and time consuming!
    you have to weld a few tack welds, then hammer the metal evenly so there’s not a step in it, move on, tack, hammer and repeat. These little holes take forever!
    I’ll be glad when this parts done!
    Unfortunately I got the other wheel well to do when I’m done with this side!
    I’m gonna do this whole left side of the car and get it done, then do the right side!
  6. 33Doll
    33Doll
    I feel Good!
  7. -Brent-
    -Brent-
    Looks like you've got it handled pretty well. Looking forward to more progress.
    kidcampbell71, VANDENPLAS and 33Doll like this.
  8. 33Doll
    33Doll
    Thanks!
    Not as nice as a pro shop, but better than Bondo and mesh in there, at least I can sleep at Night, now!
  9. BHRS
    BHRS
    from Texas
    The Pro Shop will not put the blood, sweat, and tears into this car like you are doing right now. It's part of the family and your families history. You are adding another chapter to her book. I've always tried to do as much of the work myself because I enjoy learning new techniques and the feeling of accomplishment. Once you master welding then there is body work, paint, interior, assembly, engine, etc. Keep up the great work - before you know it you will be the Pro Shop!
  10. 37 caddy
    37 caddy
    from PEI Canada
    If you are running low on metal,i usually go to my local tin shop for mine,when i get some panels bent up i always ask for some of the scraps they have,they have a stack of pieces to pick from,its usually thrown in with my other stuff. It always works for me.Usually you can do OK on it. Harvey
  11. 33Doll
    33Doll
    Not bad for a little over a week and a half!
    Frame repaired! Upper wheel well Done!
    I feel good about it! Feeling more confident!
    On to the lower, and the inside quarter!
  12. Good read mate! Love the history and your making quite a sweet job of your patch work. Look foward to your continued progress.
    Cheers,
    Josh
    loudbang and 33Doll like this.
  13. 33Doll
    33Doll
    Thanks Josh!
  14. 33Doll
    33Doll
    While The Guys at work Have been home... we have been busy.... me welding, and my buddy doing my rear window wood! He is awesome!
    Thanks Jim!
  15. 33Doll
    33Doll
    Playing around with simple ways to form curved pieces to go in the lower wheel tub Area, its gonna be tricky.
    It kind of curves in 2 different areas. The main 90* and the wheel arch its self, it kind of fades in to the bottom.
    Might just make several small pieces then, weld them together? IMG_9014.JPG IMG_9017.JPG IMG_9015.JPG
  16. Clever hammer forming on the section of pipe, nicely done!
    Cheers,
    Josh
  17. cfmvw
    cfmvw
    Just takes practice and perseverance, you're doing a great job!
  18. 33Doll
    33Doll
    Thanks!
    My Cheap harbor freight vise, angle iron, and pipe are my metal brake, and forming tools along with ballpeen hammers of different sizes. Don’t have extra Hotrod money for real shop tools right now, plus space is limited. So Im thinking how did they do it back in the 60’s before Eastwood, and Summit, etc.
    Plus I’m way better off, I have a mig welder instead of arc welder, and a big huge air compressor, and a bunch a little air tools, and thanks to Amazon, I have a whole bunch a little wire wheels sanding discs etc. for Hella Cheap!
  19. sliceddeuce
    sliceddeuce
    Nice work.
  20. Your right.
    After my 16 years in the paint and panel industry there's still nothing that I enjoy more than seeing the average car enthusiast having a go and some of the ingenious ways they problem solve. And quite often I see guys who aren't panel beaters, who aren't painters, who aren't welders etc do a better job because it's their pride and joy and they put all that much extra effort into it.
    Cheers,
    Josh
  21. Patch piece's look stout, 16 gauge steel ? Nothing wrong with using that gauge, just harder to shape. Nice Job !!!
    catdad49, Stogy, 33Doll and 1 other person like this.
  22. 33Doll
    33Doll
    Good Eye Mate!
    Yeah, it is, I figured all the inner stuff is hidden, plus its hella strong when it gets some bends in it, it also gives me some extra metal for grinding away, too.
    I have a small amount of 19g for outer stuff, and if it gets to hard to work like you are saying. We will find out today!
  23. 33Doll
    33Doll
    Moving Foward! (Literally to the front)
    One more patch before the
    “fun corner!”
  24. 33Doll
    33Doll
    Kicked Butt Today!
    Finished the Tub, all lower sections now done! Including drilled holes and spacers, Rosette welded the inner 16g
    Now on to inner rocker, and Patch panel!
    Thanks for watching!
    -Rick
    IMG_9019.JPG IMG_9023.JPG IMG_9024.JPG IMG_9025.JPG IMG_9027.JPG IMG_9030.JPG IMG_9031.JPG IMG_9032.JPG IMG_9033.JPG IMG_9034.JPG IMG_9035.JPG IMG_9036.JPG
  25. 33Doll
    33Doll
    Boy! Getting Harder now!
    Its like a puzzle, figuring where all this stuff meets! Just tacked the patch in for mock up, and to see what needs to be trimmed, cut, bent etc. plus I should mount the fender to see if the curve is Ok at the bottom!
    Gotz to use my little pea brain! Now. IMG_9048.JPG Adjustments.JPG IMG_9050.JPG IMG_9051.JPG IMG_9052.JPG IMG_9053.JPG
  26. alchemy
    alchemy
    Sight down the outer edge of the rocker from the rear axle to the front. See how your quarter patch sticks out too far? Seems you need to push the rear corner inward. See if you can make the flow from the top-down and front-back nice and smooth.
  27. 33Doll
    33Doll
    Yeah, I need to trim the lower flange, it needs to go in about 1/2, just a trial fit right now, its got 2 tacks holding it.
    Here better pics with me holding it
    Im taking it back off to finish the inside.
  28. -Brent-
    -Brent-
    I'm always impressed by resourcefulness.
    A pal of mine is an INCREDIBLE metalworker and we've joked that he might have 5 tools total in his shop. However, he proves it time and time again that it's his brain/creativity/problem-solving ability and experience.
  29. 33Doll
    33Doll
    Well tacked the panel in, used my uncles old 34’ fenders that have a nice convenient paint line for me as a guide!
    Looks close enough for me. So Im gonna remove the outer patch and finish the inside welds, then finish the outside.
    IMG_9069.JPG IMG_9071.JPG IMG_9072.JPG IMG_9070.JPG IMG_9078.JPG IMG_9077.JPG IMG_9076.JPG
  30. 33Doll
    33Doll
    So....I took the outer patch back off to start welding the inside, I forgot to take pictures yesterday of what I did inside of there. So I thought I would show you guys, for those who care! I had to build something to attach the outer panel to, because all that metal was gone!
    It looks a little Frankenstein right now but once I finish welding and grinding all the little seams it will look pretty Good!
    Just let me know if I’m taking too many pictures, I just like to share what I’m doing.
    v8paul, tb33anda3rd, Baumi and 11 others like this.
