I am fortunate enough too have two HotRod's , One car is down & will be for a while, The other car in Pretty much a Original car 32 Ford sedan , stock Front end, None split wishbone's 32 steer box 39 motor & trans 40 brakes, 40 style steer arm , 32 shock's , I have installed a Posies front reverse eye spring I will be replacing the Original 32 axle with another Orignal 32 with a 4 inch drop . Besides shorting the Tie Rod , & maybe a Kingpin kit , Will there be any other Part's or Modification needed , I dive One of my car's every Day , just would like to have all covered , Hope to be a Few hour Job , I know this is a very common change ,I read several Thread , hear on HAMB & the Ford Barn
Probably going to have to bend the spindle arms, I prefer to do that with the axle held in a vice, when your done your probably going to have to replace the bushings also
Check for clearance between the tire and front fender, both straight ahead and when turning. I think I can remember trying that on my Avatar and having an interference problem but it has been 40+ years ago and I may be remembering wrong. Charlie Stephens
