Projects 31 ford coupe rear window wood
Discussion in 'The Hokey Ass Message Board' started by Wesley Laster, Jun 30, 2020.
  1. Wesley Laster
    Wesley Laster
    does anyone know where to find the rear window wood ?? All I can find is the 30/31 roll down window options or the 32 rear wood kit . But nothing for just a standard rear window .
    I've called Mac's and Ekler's, they don't show a listing at all .. nothing comes up on Google search either..... frustrated..
  2. Can't say for sure, but check with Bratton's. 800-255-1929.
    Dino 64 and Wesley Laster like this.
  3. 31Apickup
    31Apickup
    Snyder’s lists it, I’m sure Bratton’s has it also. Have had good service from both. IMG_1033.JPG
    Wesley Laster likes this.
  4. 31Apickup
    31Apickup
    It doesn’t mention it but thee is a difference in wood in 30, as compared to 31 coupes. The 31’s is deeper which has a deeper inside window trim. This was done when they went to the roll down window option. Probably doesn’t matter if you have no wood, but if you have the inside frame it will.
  5. Model A Gomez
    Model A Gomez
    I used Fordwood in my 30 pickup and my 30 Sport Coupe, good product fit fairly well. Every body is a little different and requires some sanding. I also drilled pilot holes for all the screws after I twisted a couple off, good hard wood.
  6. Wesley Laster
    Wesley Laster
    Just when I thought I had called everyone... Thanks man
    lothiandon1940 likes this.
  7. Wesley Laster
    Wesley Laster
    Ya know , I was wondering about that ... went and saw a friend's 30 coupe ... with fixed glass , and the wood was at least 7/8" past the metal lip .. thought it was a bit far
  8. Wesley Laster
    Wesley Laster
    lothiandon1940 and Just Gary like this.
  9. Wesley Laster
    Wesley Laster
    I just wanted to thanks for the heads up on Fordwood.com.... ordered it yesterday...
    Just Gary likes this.
  10. woodsnwater
    woodsnwater
    from North Al.
    The first time I rowed through the gears in my 33 I got... Fordwood
  11. Add a bit of bar soap onto the screw threads. Helps get them installed
