Technical 31 Coupe with 32 Radiator shell thoughts?
Discussion in 'Traditional Hot Rods' started by Par34, Dec 9, 2014.
  1. Par34
    Par34
    Building a 31 5w coupe, 4" chop, 4" channel and new A frame with 8" drop rear 4" drop up front, 4" drop axle to even it out. What is your opinion on using the 32 radiator shell and insert? Also do I need to chop the shell or run full size, I know, mock it up, but just curious. Thanks!
  2. Hot Rod Nut
    Hot Rod Nut
    I vote for runnin it and chopin it!
  3. Squablow
    Squablow
    That seems like a pretty heavy chop, channel, and lowering job. You don't want the top of the radiator shell to be higher than the top of the cowl (imagine it with a hood, the imaginary hood shouldn't slope down toward the car) and with that much channel and lowering, a full height shell probably won't be possible, the bottom of it would have to be underground to get the top height correct. I think you'll be forced to chop the shell to get the proportions right.
  4. Are you a midget?
    X38, 28A and HOTRODPRIMER like this.
  5. Bawahaha,,my thoughts exactly! HRP
  6. catfishdog
    catfishdog
    from Miami
    I was wondering how one can fit in the car, it will look cool, but for sure it will be tight
  7. With the radical chop & channel 28/29 radiator might be too tall. HRP
  8. Par34
    Par34
    Don't use the 'M' word, the politically correct term is "Little person". I'm 5'-8", I know it will be tight but should work fine. Keep it stock don't chop, mild chop it blah, blah, blah! I'm going to hammer this A. My 31 pick up is chopped 5", Channeled 4" and the frame is also Z'd 4" and 8" and I fit fine. There's more room in a 5 window to start with. I want the radiator shell to be level with the cowl.
  9. Grudge
    Grudge
    I've got about 6" dropped front suspension, 4" channel, 5" chop and I'm running a full sized shell (also channeled 4") and I think it looks OK.
    Aaron
  10. walter
    walter
    looks great! I drove a 4" chopped sedan about 90K loved the look but I am glad it wasnt chaneled.
    Walter
  11. You know these 2 words don't belong togather.:D
  12. Par34
    Par34
    Never thought about it before, but yeah . You are right!
  13. Par34
    Par34
    Aaron
  14. tub1
    tub1
    from tasmania
    im too old to fold up like a spider to get in a car these days
  15. F-6Garagerat
    F-6Garagerat
    HAHAHAHAHA
    My pickup has a stock height 32 commercial shell but cab is not channeled. Like @Squablow said, imagine the line from the cowl top to the shell top. mine could actually come down maybe 3/4" I think when I look at it from the side view. I actually have a cheap hood I picked up to put on and see the line. It will need to be extended about 2" first. With a hood on it you can really see if its right. I also added the 34 commercial trim to my grille.
    kidcampbell71 and lothiandon1940 like this.
  16. Babar40
    Babar40
    from Florida
    Never thought I would be on the fence, but both stock or shortened look pretty good.
  17. Par34
    Par34
  18. Par34
    Par34
    Nice build f-6garagerat love the chopped Model A pick ups. That shell/grill looks real good.
  19. MAD 034
    MAD 034
    from Washington
    In my worthless opinion an old coupe with a deep channel running a stock height deuce shell looks out of proportion. The shell needs to be chopped to keep things looking good.
  20. F-6Garagerat
    F-6Garagerat
    Thanks. Most of it was an old hot rod a friend of mine found.
  21. Yep I agree.^^^^
    I have seen them dropped over the axle but it sounds like it is going to sit pretty low and that may be hard on the bottom of the grill shell.
    Chop it and don't look back.
  22. Too many people these days leaning towards makin your hot rod as practical and functional as a honda civic.... Chopp that thing!!!
  23. F-6Garagerat
    F-6Garagerat
    Hell yeah. My pickup is uncomfortable as hell and I love every mile in it!
    Hotrodmyk likes this.
  24. Par34
    Par34
    Thanks guys for the input, I'm thinking I will chop and channel the grille shell, it shouldn't be too difficult to make work. After all the talk about comfort and chopping, I think I will alter my plans, 5" chop, 4" channel, frame and axle Z'd 8''. I never driven my hot rods over 2K miles a year and comfort is not an issue. It's a hot rod it's got to look good!
  25. mike bowling
    mike bowling
    Seems like the radiator might be more of a problem?
  26. Walker makes a "low-boy" radiator for chevy and ford small blocks, and flatheads that is 20-1/2 inches tall.... Which should be good for at least 4'' of channel.
  27. Par34
    Par34
    Radiator won't be a problem they can build to your spec. Afco built one for my 31 PU the shell was super chopped, they nailed it and it runs real cool.
  28. verde742
    verde742
  29. Grudge
    Grudge
    I shall dub thee "Captain Quarter Inch"
    Aaron
  30. verde742
    verde742
    been called worse,,,
    Its all good... keep rollin'
