302/5.0 Tech Help?
Discussion in 'The Hokey Ass Message Board' started by Kustom.Falcon, Mar 12, 2011.
  1. Kustom.Falcon
    Kustom.Falcon
    Anything's appreciated here:
    I've got a seasoned '87-'93 5.0 that starts up great, idles well, but after running it around the block a few times, begins to sound like an old-time tractor... kind of "putting," if you will.
    Give it some time to cool down, start it up again, and it's fine. Run it around the block and we're back to the tractor effect.
    Any ideas?
    *I just replaced the dist. cap, rotor, plugs, and wires. It uses a PerTronix ignition module. Vacuum may not be absolutely optimal due to some old, bad lines. It did this before I did the plugs, wires, cap, and rotor.
  2. daddio211
    daddio211
    Are you getting enough fuel pressure? Install a gauge (even a temporary one) where you can see it while driving.
  3. Malcolm
    Malcolm
    from Nebraska
    Do you have a ballast resistor installed for your ignition? I had similar problems in my Galaxie when I changed to Ford Duraspark ignition. There was actually a factory ballast resistor wire in the dash and I had another ballast resistor inline near the engine. Too much voltage drop caused the car to run like crap. Removed the ballast resistor and it ran like a top!
    Malcolm
  4. Kustom.Falcon
    Kustom.Falcon
    daddio211: I'll see what I can do.
    Malcolm: Good question - I'll have to check the dash.
  5. Kustom.Falcon
    Kustom.Falcon
  6. 61falcon
    61falcon
    valve hanging open. if an exhaust valve sticks open, it will make a putting sound from the exhaust.
  7. Francisco Plumbero
    Francisco Plumbero
    from il.
    Pull and check your plugs? Gap good? Did you do the wires correctly? Make proper contact? Leave a vac line off? Sounds like support and not mechanical, odd that it runs OK then runs like crap.
  8. dannyego
    dannyego
    fuel line to close to the header or something cause gass to heat up and Vapor lock?? where is your temp at when it starts having issues?
  9. Ole don
    Ole don
    Time for a compression check. You may have a valve seat or guide problem. This test will tell you where.
  10. Kustom.Falcon
    Kustom.Falcon
    Good plans - I'll run them all down.
    Thanks!
  11. rustyford40
    rustyford40
    from Mass Bay
    The timing for a 5L HO is not the same as a 302
  12. check the coil.
  13. Shizzelbamsnapper
    Shizzelbamsnapper
    from Ohio
    I'm going to assume this isn't in a Mustang or anything new. Check to make sure you have a vented gas cap or that the tank vent isn't plugged. It will act just like a vapor locked fuel line. Just a thought.
  14. daddio211
    daddio211
    That's a great point.
  15. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Does your 5.0 still run the EFI? '85-92 Mustang HO motors were all EFI originally. Are you runnin the computer and oem wires to the cold start sensors? HO motors distributors run counterclock wise to 260,289 & non HO 302 engines.
  16. Kustom.Falcon
    Kustom.Falcon
    It was a long block install. Simple, old school, naturally aspirated with a PerTronix ignitor module.
    This is a recent issue.
  17. Malcolm
    Malcolm
    from Nebraska
    Did you ever figure out the problem?
  18. Kustom.Falcon
    Kustom.Falcon
    Sorry for the delay.
    Yes, figured a solution: pulled the motor and gave it away.
    Sent from my DROID device using the TJJ mobile app
  19. westcoaster
    westcoaster
    from SoCal
    now how are we going to sleep tonight? knowing that we'll never know what the problem was? :)
  20. fordor41
    fordor41
    Also a bad PCV will make the exhaust loud but usually at idle.
