Projects 30 model a
Discussion in 'Traditional Hot Rods' started by Carl Gibbs, Jan 10, 2021.
  1. Carl Gibbs
    Carl Gibbs
    Hey guys pretty new to this. I've been lurking on this site for awhile trying to get ideas. Started gathering parts to build a traditional hotrod. I have no back ground in hotrod or building cars. But have been wanting to do so for a few years. I picked up a frame awhile back. Just recently found a body that was in my budget. I built a stand in my garage to set the fram on and box it in. When I'm done with that I'll set the body up and start replacing patch panels. 20210105_201313.jpg 20210108_200818.jpg 20210105_201313.jpg 20210108_200818.jpg
    brEad, swade41, patmanta and 13 others like this.
  2. sloppy jalopies
    sloppy jalopies
    Nice body...
    where are you from ? may be hambers close to home...
    Check to see if the frame is bowed before you box it... they sag near the motor mounts...
    if you don't fix it the hood grill lines will be wrong... now is the time...
    1952henry and Blues4U like this.
  3. Carl Gibbs
    Carl Gibbs
    I am from Albion Michigan. I got the frame all set up . Is a slight tweak. I was going to clamp it down before I welded them in. I'm pretty new to this so I am learning as I go.
    AHotRod likes this.
  4. getow
    getow
    Looks like a good start. Keep posting pics of your progress.
  5. -Brent-
    -Brent-
    Chainsaw, Millermatic, and an engine hoist... I think you'll be fine.
    What's the plan for an engine?
  6. 65stang85
    65stang85
    from michigan
    Nice, I'm doing a similar build right next door, just south of Battle Creek.
  7. Carl Gibbs
    Carl Gibbs
    I'm not sure plan on engine yet. I'd love to do a flathead with tall and skinny whitewall tires . And keep it as close to a traditional hotrod as I can But right now I'm just parts collecting and trying to get ideas.
    HuskerNation, Blues4U and -Brent- like this.
  8. 41rodderz
    41rodderz
    from Oregon
  9. Carl Gibbs
    Carl Gibbs
    Awesome id love to see some pics of the progress
  10. brady1929
    brady1929
    Great project.
  11. 65stang85
    65stang85
    from michigan
  12. Blues4U
    Blues4U
    from So Cal
    Welcome to the HAMB! Looks like a great project. You'll get plenty of help around here. Do yourself a favor and check out Aaron's videos of his project, he did a great job of documenting everything about the build, his videos are a treasure trove of information:
    https://www.youtube.com/channel/UCXvmgam2BOgAFO35_u4X2bQ/videos
    lothiandon1940 likes this.
  13. LUTHER99
    LUTHER99
    Great start , keep pics coming.
  14. Carl Gibbs
    Carl Gibbs
    Thanks for all the info . This site is awesome and ill definitely have questions as I go.
  15. AHotRod
    AHotRod
    Real Hot Rods Rule!
    Texas Webb likes this.
  16. 51504bat
    51504bat
    Plus a zero turn mower so yard work doesn't get too much in the way of hot rod building.:cool:
    Texas Webb and -Brent- like this.
  17. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Well you've got a great start, frame table and what looks like a really clean body. Well on your way for someone who doesn't know the drill.
    -Brent- likes this.
  18. 65stang85
    65stang85
    from michigan
  19. Carl Gibbs
    Carl Gibbs
    Barn has been cold.:confused: Just started the z in the rear of the frame and boxing the frame in. I'll post it when its complete. Otherwise parts collecting. And following your posts and a few others.
  20. sloppy jalopies
    sloppy jalopies
    I am not new here but i like to see progress pix as I learn the ways others work...and tools they use...
    Don't have to wait till a little job finished... pix as you go... don't worry that your welds don't look like a row of dimes....
    Plus some of the guys may notice something you didn't think of and it save you a bunch of frustration...
    post your "propped -up" pic... we have all been there...
    ... GO CG GO !
  21. 65stang85
    65stang85
    from michigan
    Nice, I'll be tackling the body mods for the Z'd frame soon, have you decide on a drive train?
  22. Carl Gibbs
    Carl Gibbs
    I realy wanna go with a flathead. I just haven't gotten ahold of one yet. My goal at this point is to get the frame on axles and rolling.. I will take some pics of the progress and post them this week.
  23. sloppy jalopies
    sloppy jalopies
    if it helps any i have an 8BA oil pan, cast bellhousing, starter and starter plate, cheap, at 04210 ...
  24. Carl Gibbs
    Carl Gibbs
    I appreciate it. I'm going to find a whole motor and then see what I need from there.
  25. Carl Gibbs
    Carl Gibbs
  26. Carl Gibbs
    Carl Gibbs
    So this is where I'm at. Frame is zd. And started boxing frame. I'm going to make some plates to go over z'd section and clean it up alittle.
  27. Carl Gibbs
    Carl Gibbs
  28. Never2low
    Never2low
    I’ve got a mostly complete ‘39 or ‘40 flatty and a ‘39 big fork synchro trans in my garage that needs to find a new home since I sold my ‘30 coupe project. I’m in Muskegon, and I have a truck if that helps you. I can get you some pics when I get home from work.
    Jeremy
  29. wheeldog57
    wheeldog57
    Atta boy, looking good. Keep at it and keep us posted
