'30 Model A top
Discussion in 'The Hokey Ass Message Board' started by Smilin Jack, Mar 7, 2013.
  1. Smilin Jack
    Smilin Jack
    I'm starting my Model A coupe build and need advice. Should I do a metal roof or replace the black vinyl? I'm painting cream orange and like the look of the black vinyl against the orange but replacing with metal might be easier. I'm not chopping or channeling and the body itself will be close to original. Somebody give me a tie breaker opinion.
  2. scrap metal 48
    scrap metal 48
    Did this to my old coupe for about $60 and a weekend...
  3. Smilin Jack
    Smilin Jack
    Thanks, looks great. I'm not sure how good a job I can do of the vinyl top though. I want a neat job. Of course, not sure how neat a job of the metal top I could do either. LOL
  4. Vergil
    Vergil
  5. gnichols
    gnichols
    from Tampa, FL
  6. jimbousman
    jimbousman
    Here's one I saw on this site a few weeks ago.
  7. Smilin Jack
    Smilin Jack
    Vergil,
    You're a true craftsman. You gave every detail I wasn't sure of. My black top will look great on my cream orange coupe. Thanks so much!
    Jackie
  8. boutlaw
    boutlaw
    I filled my 31 coupe roof with a 72 Maverick roof insert, but now I think I would prefer the vinyl, especially if I could slide the roof open or remove it easily on nice days. Options are always nice.
    BOutlaw
  9. Smilin Jack
    Smilin Jack
    Boutlaw,
    I'm not sure I could get a smooth metal top on my car. At least vinyl is easy to remove if I make a mess. LOL
  10. Vergil
    Vergil
    Gary ... Jack ... thanks
    Vergil
  11. Gumball
    Gumball
    from Vista, CA
    I filled the roof with the roof off a 65 Dodge Dart, turn in backwards and it fit so close that we didn't have to do anything but weld it in.
    Have fun..
  12. charlieb66
    charlieb66
    You can do an imitation vinyl top over a filled metal roof. The joint between the visor and the panel over the door can present a problem, I think it is best to weld this joint no matter what roof you chose.
  13. papajohn
    papajohn
    I think filled metal roofs on Model A's look goofy. I do like the idea of the slider, it looks cleaner than a snap on, and more fun then a stock type vinyl roof.
    Just my 2cents.
  14. Canuck
    Canuck
    Using Vergil's as one of my inspirations, I have all the stock style wood framing. Tacking a metal filler (668 Chevy full size fits great with no re-shaping) around on the inside of the raised bead. Cover with some closed cell foam then install stock style vinyl same as original. Bend up some repro aluminum trim to finish all the edges and install on a sealer base.
    Canuck
  15. Smilin Jack
    Smilin Jack
    Vergil,
    Your build post gave me a bit of confidence. I tore off the vinyl top that was on my car. It was a very bad restore job. Some of the top wood is bad along with the front header wood. I can replace that with no problem. The arched cross wood pieces were not arched anymore but were sunk down. A little oak will solve that problem. I'm definitely following your build and gonna go for it. Thanks.
  16. Vergil
    Vergil
    Jack with your outlook it will go great ....
    Vergil
  17. Smilin Jack
    Smilin Jack
    Vergil,
    I'll post pics when I get started. I'm sure I'll have questions . My top metal was surprisingly good. I though it was a rusty mess but it turned out to be mostly brushed on paint from years ago. LOL
  18. bgaro
    bgaro
    good choice
  19. Tnomoldw
    Tnomoldw
    :)Keep smiling ,Smilin Jack ! It going to be a good project..:cool::D
