Technical 29 roadster top
Discussion in 'Traditional Hot Rods' started by Deuce Man, Dec 30, 2020.
  1. Deuce Man
    Deuce Man
    I called Sid Shavers today looking to order a top for my 29 roadster. Sid doesn't make tops for 28 29's so guys who does? any help will be appreciated Rich
    dana barlow likes this.
  2. I made my own top. Welded up a perimeter frame from 3/4" square steel tubing, then added the center bow at the height I wanted. You can determine the shape by tacking things together and laying an old sheet over it to see the shape. After it was all finish welded, I took it to my upolstery guy who covered it with Mercedes Benz cloth. It's padded, and covered inside and out, like a Carson top.
  3. chev34ute
    chev34ute
    And this is what the frame looks like. I will see if I can get measurements from the owner. C023AA9A-F202-49C2-B67C-111FF92F79BA.jpeg 237C2AA6-AD5D-437D-AB69-E49BD80C31B8.jpeg
    dana barlow and ramblin dan like this.
  4. Romanceofcrime
    Romanceofcrime
    Mike’s Upholstery in Whittier California might be able to help you he’s done a few of these
  5. ydopen
    ydopen
  6. Visited RodTops shop a few years back, talented crew.
  7. iafraser39
    iafraser39
    from Warmland
    I made mine and it folds up.
    Got the local shop to do the upholstery.
    Make sure you put a Zip out rear window, otherwise
  8. Make your own.
    1/2" conduit, rent a conduit bender for a day and make up a frame. Next do the carson style top deal with it, cover it with chicken wire, some batting on top of that and sew up a cover from the material of choice.
  9. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Jet96 likes this.
  10. The top won't "flap" if it's made like a Carson top. Though I did have a zip out rear window section made for ventilation in the summer.
  11. Stan Back
    Stan Back
    Follow Dean's near-stock design with the "V" in the upper portion. I had a "custom" one with a curved kinda "Carson" look to it. Going about 70 MPH into an about 70 MPH Santa Ana wind ripped it off along with mangling the bows.
  12. Deuce Man
    Deuce Man
    All great advice guys, my last 32 had a duvalle windshield and a shavers top, I loved it. I am presently building a new chassis for my 46 business coupe and am getting ready to build a 62 ft sportfishing boat for someone, Yes that is what I have done for a living for the past 40 years. My creative side is really up to the full mark, and I just want to buy something. Besides the local top shops around here would probably want twice as much to cover my homemade frame as a Shavers or Rod Tops top would cost. By the way you guys have built some killer tops for your cars, my situation is a little different now. Thanks Rich
  13. rusty_bits
    rusty_bits
    ConvTop 6.jpg ConvTop 6.jpg As others before, made my own.
  14. sloppy jalopies
    sloppy jalopies
    If you make your own top bows, get the unions and pivot fittings before you buy conduit...
    they don't make all sizes of the fittings...
  15. Dirty Dug
    Dirty Dug
    carwithtop.jpg topframe1 (1).jpg topframe3.jpg Make your own. I don't understand using conduit. I know this is a '30 but the same thing could be done with an early Model A roadster as well.
    Algoma56 and badshifter like this.
  16. walter
    walter
    I used a 31 DELUXE top irons and had Bentwood Bows steam been new bows the width of a 29 body and then chopped the irons to my taste. Folds great and mounts in original mounts.
    Dirty Dug likes this.
