Customs 283 ENGINE
Discussion in 'The Hokey Ass Message Board' started by Mister E., Feb 27, 2020.
  1. BoogittyShoe
    BoogittyShoe
    Re: "...not as savvy..."
    Never feel bad about what you don't know. No one knows anything until they learn it.
    This is wayyyy off subject, (but it is about "lesson learned"). I thought I would splurge and try a crab salad from Walmart. Never tried it. Big letters- CRAB SALAD. I got home and in little, thin, squeezed-together letters - " Imitation Crab Meat". What is that?
    I should have learned ("Read the fine print") the time I got home with imitation honey. Looked like Valvoline 50 weight.
    Kan Kustom and Mister E. like this.
  2. Mister E.
    Mister E.
    from USA
    Ok, well that's another thing I will have to address when the time comes.
    I actually like my foot starter, but if it's not compatible then I guess it is what it is.
    Thanks
  3. ROADSTER1927
    ROADSTER1927
    Put the regular starter on and put a button type switch under your start pedal. no linkage needed!:)
  4. Hollywood-East
    Hollywood-East
    If you're going to regasket it, I would highly recommend a new oil pump/timing chain set (as mentioned) valve seals should come in gasket set.... Both will be reused even if there is the knock of doom...
  5. squirrel
    Perhaps you're not familiar with how the Chevy six foot pedal starter works? The pedal assembly is attached to the bellhousing, and there is no provision for it on the V8 bellhousing (as well as no easy way to get the linkage where it needs to go to work).
    lousy pic, I don't have any handy to take a better picture of.
  6. Mister E.
    Mister E.
    from USA
    That's exactly what I plan to do, tear down, clean up, regasket, and pray for the best outcome!!
    Kan Kustom and Deuces like this.
  7. Mister E.
    Mister E.
    from USA
    Btw, looked closer at oil pan, there is a big dent in the bottom of it, so I most likely will have to replace it, since I dont think it's possible to bang out an oil pan without damaging it.
    If I'm wrong, please let me know.
    Thanks
  8. Ive straightened several oil pans that where simply dented. Mostly on farm tractors. as long as the gasket surfaces are good. they will be ok.
    Kan Kustom, Deuces and Mister E. like this.
  9. How bad is the dent,,,,almost anything can be straightened .
    Tommy
  10. Mister E.
    Mister E.
    from USA
    I will take picture and show what I am concerned about.
    Thanks
  11. Six Ball
    Six Ball
    from Nevada
    I'm following this to see how you do. I have a 283 that came from my Grandfather's '67 Chevy pickup. It was smoking some in the late 70s so he and my uncle installed a junk yard 327. I've had it since then and it has resided in the corners of 3 different shops. It has never been opened up and always been under cover. I'd love to put it in something someday. I have a nice close ratio Saginaw that that would like to be behind it.
  12. Mister E.
    Mister E.
    from USA
    Just added some pictures.
  13. You’re right,,,it took some good hits,,,but nothing that can’t be fixed very easy .
    Do you want to save the pan for sentimental reasons or don’t care .
    You can replace it fairly easy,,,or spend an hour or so and fix what you got .
    Be creative with some wood and a hammer .
    Those dents will come right out,,,if you really want to do a perfect job,,use a bag with lead shot.
    Just take your time,,,nothing to it .
    The good thing is looks like the pan rail is perfect,,,that is the most difficult to fix,,,so you should be good .
    Tommy
  14. Mister E.
    Mister E.
    from USA
    Not sentimental about the pan, but I'll try the hammer and a small 2×4 piece and see how it does.
    If I dont need to spend extra $$ on things that can be fixed then all the better, but whatever does need replaced I will definitely be taking care of those asap.
    I'm on a fixed income, so it won't be a speedy thing. I'll just buy what I can as I need it and go from there.
  15. Hollywood-East
    Hollywood-East
    A straight used pan hot tanked from a local machine shop is as cheap/Rite as it will get... Unless your buddy has one...
    6-bangertim likes this.
  16. Hollywood-East
    Hollywood-East
    Your pan is intercoursed... IMO
    Only.... Because being around drain.... Shit gets weird real fast trying to straighten that out an not leak ... Yes it could be saved with someone with a torch an fineness...
    Deuces likes this.
  17. Mister E.
    Mister E.
    from USA
    Well that figures!
    Deuces likes this.
  18. ROADSTER1927
    ROADSTER1927
    I have a couple 50 Chevy trucks so I am familiar with them. He could disconect all the linkage put a spring and a stop on the pedal. Mount the switch right on the floor or under the cab for the pedal to touch. Gary
    raven likes this.
  19. Jessie J.
    Jessie J.
    A scrapyard 283 I bought had a clunk-clunk sound when the crank was turned back and forth, was advised it sounded like a loose timing chain, put a new timing set on it and that dang clunk was still there.
    Pulled the oil pan and #3 rod was so loose that I could rattle it. My buddy junkyard mechanic went to his tool box and dug around a bit and came up with a single set of rod bearing inserts, put 'em in and we sealed her up.
    Engine and a used Power Glide ended up in my '62 Rambler Classic, soon after to be equipped with a Duntov solid lifter cam (turned out the original cam had a flat lobe) Weiand Hi-Rise and AFB.
    Ran the hell out of that thing for the next 2 years, with many blasts up to 6000 rpm and over 100 mph, never had the engine apart again, and when I sold it, it was still running great.
    Anyway, If you are pulling the oil pan to bang it out and seal it up, might think of sticking in a set of rod bearings.
    The Force be with ye.
  20. Mister E.
    Mister E.
    from USA
    Going to be checking everything out to make sure what it needs, and what it doesn't necesarily need at this point.
    Anything it needs that is of major concern will be done right away.
    First things first, it needs a good cleaning and start labeling / logging each part for disassemble.
  21. Mister E.
    Mister E.
    from USA
    Trying to find a bellhousing for this 283 as well as correct gasket set so I can start tearing into it and see what shape everything is in.
    Proving to be a bit of a challenge, I can thus far only find head gasket, valve cover, or oil pan gasket.. But not a full gasket set.
    I'm hoping once I open it up that I won't need to replace anything major.
    I did price out fuel pump, water pump, since they both need to be replaced anyway.
    Picking up fuel pump later today.
    My main concern is to get the engine cleaned up, making sure it's not broken or damaged internally or anything and get ready for transplant!!
    Will keep you all posted.
  22. squirrel
    I'd do the inspections and checks before buying parts....just in case.
    you seriously can't find a gasket set?
    (...and ignore the head bolt BS, you don't need to replace the head bolts unless they're rusted away)
  23. Mister E.
    Mister E.
    from USA
    Oh damn, I didn't even think of rock auto, cut when I called they said they didn't carry anything for the year of my truck!
    Thank you for this, which gasket set is correct for my truck?
    I believe I go by year of my truck with the 283, or do I go by year of engine?
    Just want to make sure I get the right one.
    Thank you
  24. squirrel
    Are you buying gaskets for the truck, or for the engine that's going into the truck? Seems pretty clear to me.
  25. Mister E.
    Mister E.
    from USA
    For the 283 engine.
    Yeah, now that I read that, I got it.
    Still on my first cup of coffee here , lol
    Thanks Squirrel
    Kan Kustom and s55mercury66 like this.
  26. squirrel
    glad to help.
  27. BoogittyShoe
    BoogittyShoe
    I just had a thought. (Yeah, this early)
    If you haven't tried working out the oil pan dent yet, put the drain plug in from the inside. (really tight) I think the head will make a good surface to strike it and if it's tight it won't damage the threads. I'd put it on the ground to hammer it. That will support it around the dent but still let it (*thinking of word*) re-form. (?)
    PS: Think "I WILL fix this oil pan."
    Hollywood-East and Mister E. like this.
  28. I have a good supply of those truck bellhousings. however shipping would be expensive.
    Mister E. and Desoto291Hemi like this.
  29. squirrel
    I'm down to only having two of those bellhousings, and places for both of them to go....
  30. Mister E.
    Mister E.
    from USA
    How much?
