Hot Rods 28-29 Model A with Y-Block Running Full Hood?
Discussion in 'The Hokey Ass Message Board' started by bradberry00, Apr 3, 2020.
  1. bradberry00
    bradberry00
    So while in social quarantine, I have a lot of time to think about future projects. I have bits and bobs, engines and bodies in storage. They are spread across a couple states waiting for the day I finally get my garage built at my house. But, planning and thinking are always fun....My newest plan is to run a y block in a '29 Model A on '32 rails....one issue I can see (in my brain) however, will that wide engine fit with a full hood?? I am a big fan of full louvered hoods on these Model A's....I have seen many without a hood or no hood sides, but show me a 28-29 A with a Y Block under the hood (literally under and in between a full hood).
  2. Jalopy Joker
    Jalopy Joker
  3. I don't think you'll have a problem with width so much as length. I had to move the front x-member 3" to make it fit and I'm still a bit too tight on the firewall. That's all waterpump and fan between the block and radiator. I had a one piece hood made, no sides. 0907181620a-1.jpg
    bradberry00, RHRH3P and Texas Webb like this.
  4. bradberry00
    bradberry00
    Length shouldn't be too much of an issue as I plan to go with a 32 frame, that should give me about 2 1/2-3" in added wheelbase. Also, there is a short timing cover available from John Mummert. To me it looks like the exhaust manifolds could give me the most difficulty when trying to put on hood sides.
  5. 32Dan
    32Dan
    from Chino, CA
    [​IMG][​IMG]
    I know you asked for model A, but my deuce is the best I can do! This should give you a little perspective on the width of the Y Block. Yes, exhaust manifolds will stick out another 2 1/2” on each side, but you can probably get away with making your own block huggers. Recessed firewall will also most likely be a must. My engine is a 312 and uses all the original parts on the front of the engine. Good luck in the project, look forward to seeing it!
    bradberry00 likes this.
