235 Chevy - to rebuild or not to rebuild
Discussion in 'The Hokey Ass Message Board' started by Ryleej3, Feb 10, 2013.
  1. Ryleej3
    Ryleej3
    from Washington
    I am pulling my 235 Chevy motor from my 1954 Chevy Bel Air. I did a compression test and a coolant test before I pulled the motor. Based on the results I didn't bother to do a leak down test. At this stage the motor is pulled apart enough that I can't run more tests. I want to share the results of the test with the forum to get some feedback. Based on the results I don't plan to rebuild the engine. Curious what others think.
    Keep in mind that at some point I'll probably swap out the 235 for a 350 SBC and 700R4 so I'm trying to avoid putting much money into the motor. Also, I am OK with cars but engine rebuilds are something I would pay someone else to do.
    So....
    Here are the results of the dry compression test.
    1 - 95
    2 - 100
    3 - 110
    4 - 100
    5 - 110
    6 - 110
    Wet compression test results.
    1 - 115
    2 - 120
    3 - 120
    4 - 120
    5 - 130
    6 - 125
    Spec says that compression should be 135
    Engine ran good before I started to pull it. Small amount of white smoke on startup. Spark plugs look OK. Top half of engine was rebuilt 100 miles before I started to pull the engine. Unknown miles on bottom half of engine but based on a visual inspection from my mechanic the cylinder walls looked good.
    I did a coolant test and it didn't show any gas escaping into the coolant.
    I'm feeling like I can skip the rebuild on the lower half of my engine and run it like it is. Anyone think I'll regret this choice?
  2. fastcar1953
    fastcar1953
    i would leave it alone. looks healthy to me. save the money for the v8 swap.
  3. Run it, and enjoy.
  4. HUSSEY
    HUSSEY
    If it ran good why all the fuss? Put it back together and run her till she drops.
  5. belair
    belair
  6. GREASER815
    GREASER815
    Keep running it until it scatters, and don't waste money rebuilding it. I picked my running 235 up for $100, just get another one and run it until it blows as well.
  7. Vimtage Iron
    Vimtage Iron
    I just went thru the top of a 235, head was cracked, so we got a good head went thru it and put it on, now I'm kicking myself for not putting rings, the cylinders looked great so I left it alone, now its sucking some oil. If you have the head off already,it sounds like you do, then put a set of rings in, you'll be happier later.
  8. 226 flattie
    226 flattie
    from orange,ca
    Run it and save the dough. The compression on each cylinder is not way too much different from each other. These engines will run for ever as long as it has oil in the crankcase .
  9. pinkynoegg
    pinkynoegg
    i would run it. the 235 has plenty of torque and should be fine with a little compression loss
  10. Dane
    Dane
    from Soquel, CA
    How much is a set of rings and a ball hone?
  11. aussie57wag
    aussie57wag
    from australia
    Run the 235. sbc and autos are for people with one leg and no imagination. A tripple carb 235 will look way cooler than a sbc when you open that hood, aand built right it should be as dependable.
  12. R Pope
    R Pope
    Rings, rod shells and a valve job will give you an engine that will run for years. Like Dane and Aussie said. I wish I still had the original 235 for my '54 Bel Aire HT. A cam and dual carb/dual exhaust is cheaper than a 350, and much cooler.
  13. cartoon14
    cartoon14
    run it, save the money, swap her out when she's done...
  14. Hotrod 35
    Hotrod 35
    If you need a 235 and 3 speed trans leve me a note.
  15. teddyp
    teddyp
    run it for now save up and put a 350 with a 4 sp. in it and have fun
  16. Ryleej3
    Ryleej3
    from Washington
    Cool. Thanks for the feedback everyone. I've decided to leave it as is. At least for now.
  17. Ryleej3
    Ryleej3
    from Washington
    So I pulled the engine and cleaned all the gunk off. Engine is ready to be media blasted and painted. Found a big long crack running lengthwise along the bottom of the block just an inch above the oil pan. It was leaking coolant out of the crack. Glad I pulled the engine and found the crack. I'll have it welded up and block should be good for a few more years.
  18. Probably froze up one winter. Those sometimes close up nicely with an application of a block-saver product and it runs forever. Welding up the crack is way more involved.
    Bob
  19. belair
    belair
    I will get pooped on for this, but some block sealer on the inside and JB-Weld on the outside, and you are done.
  20. no.scar.no.story
    no.scar.no.story
    Since you have the engine apart, is there any evidence that coolant might be anywhere else it doesn't belong (ie in the oil pan)? A careful inspection is in order. That might not be the only crack in that old block.
  21. Good advice, although the project to save the block may spiral out of control fast. I would be taking the bare block to the local machine shop to have it cleaned and inspected, let them make the call.
    Bob
  22. Ryleej3
    Ryleej3
    from Washington
