Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    did a little more grinding on the perch brackets? to soften the curve
    and reversed them to push the shackle mounts outboard to use a longer spring
  2. Paul
    Paul
    Editor
    mounted spindles to check clearances,
    definitely need to bend the steering arms
    there is crashing at shackle to steering arm and shackle to tierod..
    I may turn them back and go with a shorter spring
    that will require bending both the spring perches and steering arms but might provide the best solution..
  3. Paul
    Paul
    Editor
    bolted on some wheels and propped things up again to check proportions
    had this ancient radically chopped '32 shell on the wall, leaned it more or less in place.
    front and side are looking OK, rear might look better with a few more parts to fill it out
  4. Gene Chan FTW! Love it @Paul!
    Paul, Stogy and loudbang like this.
  5. Paul
    Paul
    Editor
    Gene Chan! That's the name, thank you!
  6. Paul
    Paul
    Editor
    Love the overall stance and proportions
    I could study that car all day
    Stogy, cactus1, kidcampbell71 and 2 others like this.
  7. flatheadgary
    flatheadgary
    from boron,ca
    did i miss something? how are you going to use a 4 bar with that spring hanger?
    Paul, loudbang and dana barlow like this.
  8. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Yup,that's pretty cool T,very sharp.
    Only thing showing in photos that may be better,is if the front rims set inside a small bit,as is in photo,looks like they are out set a little too much=too much scrub to front wheels{ that can make steering an braking act a bit funny an do stuff,that would not happen if scrub was set right.
  9. Desmodromic
    Desmodromic
    How do you intend to prevent the spring perches from rotating around their vertical axes? The spring shackles, necessarily at a considerable angle, will create a horizontal load roughly equal to the corner weight of the car, tending to cause rotation.
  10. Paul
    Paul
    Editor
    All will be revealed as work progresses
  11. alchemy
    alchemy
    Hard to tell with your angled pics and the magazine pics of the Chan car, but I think maybe you could bring your rear axle forward a couple inches. And maybe bring the front axle back an inch too? Just to give it the "cute as a bug" look. Like Weesner draws. Do you know the wheelbase of the Chan car?
    Paul and Stogy like this.
  12. Paul
    Paul
    Editor
    I don't know the wheelbase of the Chan car,
    But do agree about moving major components around to create a more balanced and pleasing look.
    I am not working from a specific plan, it will be, as is the case with all my projects, an evolution of ideas based on an incomplete image in my mind formed as a composite of various examples of similar builds.
    It is a work in progress
    Atwater Mike, Stogy, bct and 7 others like this.
  13. 64 DODGE 440
    64 DODGE 440
    from so cal
    In other words...a proper hotrod.
    Paul, chryslerfan55 and loudbang like this.
  14. pitman
    pitman
    Typ. A wheel base = 103-15/32"
    loudbang and Paul like this.
  15. Paul
    Paul
    Editor
    back at the parts pile..
    found some old chrome front suspension pieces..
    a little on the small side but food for thought just the same
  16. Paul
    Paul
    Editor
    spent most of the day moving stuff around,
    pulled the rearend of choice from the stack,
    (of course it's at the bottom of the stack)
    early '60s? Pontiac/Olds 9.3 posi,
    put it on the cart to drag it outside for clean up
  17. Paul
    Paul
    Editor
    set the body on an A frame to visualize and measure for surgery
    Lil'Alb, Nailhead A-V8, Stogy and 7 others like this.
  18. Some really nice work! Looks like you have a great parts selection...
    Paul, Stogy, loudbang and 1 other person like this.
  19. Paul
    Paul
    Editor
    took advantage of the beautiful roadster weather to gather up some more wire cups, grinder discs and misc junk to clean up the rear
    Moriarity, brEad, J_J2 and 8 others like this.
  20. Paul
    Paul
    Editor
    and spent the rest of the day cleaning the remains of the brackets and crust
    and pulled the brakes off, one side wet and fairly well preserved, the other dry and rusty
    'pretty sure I have better drums and backing plates around somewhere..
    IMG_20200316_120641.jpg IMG_20200316_170830.jpg IMG_20200316_171114.jpg IMG_20200316_171106.jpg IMG_20200316_182911.jpg
    brEad, J_J2, OFT and 6 others like this.
  21. Paul
    Paul
    Editor
    date code says December 13 1962,
    stamped OL makes it a 3.08:1 Limited Slip
    casting shape makes it a 3rd generation.
    brackets removed looked like Pontiac.
    pitman, OFT, cactus1 and 4 others like this.
  22. Paul
    Paul
    Editor
    Changed the thread title as the Hulk lettering went away with the alternate rear cab section and I think of it more as a roadster than a bucket now with the turtle deck
    Stogy, AndersF, bct and 1 other person like this.
  23. Paul
    Paul
    Editor
    Dug a spare block and heads out, bolted a bell and transmission to it, set a spare manifold on all to mimic the J2 setup that will likely go in it
    and rolled that between the frame rails.
    Ground clearance under pan is close to where it should be, frame could come down a touch, body needs to come down about 4", maybe more..
    Lil'Alb, chryslerfan55, brEad and 5 others like this.
  24. 64 DODGE 440
    64 DODGE 440
    from so cal
    The more I see of this build, the more I like it.
  25. Stogy
    Stogy
    Go @Paul Go...the Hulk meets Ratfink...Ally Oop...;)
    pitman and Paul like this.
  26. Paul
    Paul
    Editor
    Shoving stuff around some more
    Plan was to modify the A frame but it looks like it'd be easier and faster to fab a new one..
  27. Paul, you build some of the coolest stuff in my opinion. The fact that they are Olds powered is just the cherry on top. Keep on rocking!
    J_J2, pitman, bchctybob and 3 others like this.
  28. Marty Strode
    Marty Strode
    Looks great Paul, and those A frames are a lot of work, compared to tube.
  29. Paul
    Paul
    Editor
    Thanks Marty, Speedy, Stogy and all
    Long way to go here but it's fun seeing it finally take shape
    chryslerfan55, Stogy and cactus1 like this.
  30. Paul
    Paul
    Editor
    Stole away to the shop for an hour or so
    Swapped the hangers side for side and heat/bent them to work with the shorter spring..
    Shackles should just clear the arms and tie rod now.
