Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    I needed a nut for the clutch fork rod.
    'was sure there was one around here somewhere.
    dug through all the usual places it might have been stashed in,
    nope..
    placed an ad,
    got impatient.
    decided to see if I could make one.
    dug through the junk nut and bolt drawer,
    chose a 1/2" lug nut.
    chucked it up in the drill press and used a file to create the domed end,
    then the little grinder with cut off wheel to cut a groove.
    drilled it through with a 1/2" bit.
    chucked up a couple 3/8" nc nuts and filed them round to about .502",
    used the vise to press the rounded nuts in using a piece of all thread to keep the threads aligned.
    welded them together.
    chucked it back in the drill press and filed both ends clean.
    done.
    probably could have found a replacement on line
    and waited,
    or if I had a lathe and knew how to use it...
    anyway this is what you can do with junk and a couple basic tools..
    and little patience
    IMG_20200711_083712.jpg IMG_20200711_084412.jpg IMG_20200711_090018.jpg IMG_20200711_094734.jpg IMG_20200711_094424.jpg IMG_20200711_101241.jpg 2 IMG_20200711_105136.jpg 2 IMG_20200711_105131.jpg
  2. Paul
    Paul
    Editor
    This is what it looks like in the fork
  3. Nice work on that door! You are a talented sumbich!
  4. Fantastic, Paul. You made that look easy. I would never have seen the finished piece in that lug nut. My "HERO" of the day.
    Ben
  5. Paul
    Paul
    Editor
    Worked on the pedals.
    Using an Ansen style swing pedal setup
    turned around and mounted under the floor.
    Made paper pattern.
    Cut, grind, drill 1/4" steel plate
    Cut Original pedals off
    Weld new on.
    Trim, bend, drill and tap for pads.
    Test fit.
    Getting close, a few minor adjustments, a frame mount and it should work fine.
    IMG_20200713_112510.jpg IMG_20200713_131048.jpg 00000IMG_00000_BURST20200713143020887_COVER.jpg IMG_20200713_151744.jpg IMG_20200713_151937.jpg IMG_20200713_154854.jpg IMG_20200713_161012.jpg IMG_20200713_174744.jpg IMG_20200713_180656.jpg IMG_20200713_182148.jpg IMG_20200713_182207.jpg
    brEad, 51box, kidcampbell71 and 11 others like this.
  6. Paul
    Paul
    Editor
    I knew I'd seen this done before,
    using the Chevy pickup master turned around and under floor but
    'couldn't find any examples until just now
    seeing construction pictures of Robert Williams chassis
    in the recent Youtube video here
  7. flatheadgary
    flatheadgary
    from boron,ca
    i must be missing soemthing. why wouldn't it work? the mc doesn't know or care which direction the rods are going in. i don't think it would work upside down though. hahaha
    Stogy, loudbang and Paul like this.
  8. Paul
    Paul
    Editor
    Mount for Ansen style bracket to bolt to
  9. Paul
    Paul
    Editor
    I'm going to run the lines out the ends of the master cylinders, if run down out the stock holes the lines would hang down too low.
    'used a long 3/16" bit through the bore to ensure holes would be centered,
    Drilled larger with 5/16" from the outside,
    Filed flat spots on the ends
    and tapped the holes with 1/8" np thread
    Screwed a couple fitting in as place holders
    and to check thread depth.
    Push rods were just kissing the pistons
    So I relieved them a touch
    And put the master back in to check fit.
    Stock holes will get plugged.
    IMG_20200719_165950.jpg IMG_20200719_172458.jpg IMG_20200719_172335.jpg IMG_20200719_180239.jpg IMG_20200719_181850.jpg IMG_20200719_164942.jpg IMG_20200719_164915.jpg IMG_20200719_182725.jpg IMG_20200719_182748.jpg
    Atwater Mike, Jet96, brEad and 12 others like this.
  10. alchemy
    alchemy
    Wow! Whoda thunk? Good job!
    kidcampbell71, loudbang and Paul like this.
  11. bchctybob
    bchctybob
    Don’t you know you’re not supposed to modify a master cylinder!?
    loudbang, Stogy and Paul like this.
  12. Stogy
    Stogy
    'That's the Brakes'...:D...Genious Really...many Hambers could have revolutionized the Daily Driver Car Industry...Glad they chose Hotrods though...;)
  13. lake_harley
    lake_harley
    I would expect the "You're Gonna Die" folks will be along any time with criticism of modifying a MC, but it's not me. I'm enjoying your build thread and admire your solutions to challenges along the way. To me it's kind of a "white sheet" build....lots of innovation and beautiful fabrication.
    Lynn
    bct, Tman, kidcampbell71 and 3 others like this.
  14. Speedy: 'Oh, he's going to have to run 90º fittings off of that MC...
    Paul: 'WRONG!' :D
    Great work Paul. Love your logical approach to this thing. It's definitely helping me to think differently with aspects of my build as well.
  15. loudbang
    THAT is some great original thinking.
  16. Sh*t man. "Innovation" with 60 year old parts is a misnomer.
    Wow, that is cool !!!
  17. Paul
    Paul
    Editor
    Actually thought about that too, and it still may happen.
    I have another master I have been using for mock up, I could drill out the stock flare connections and tap them to take 90° fittings.
    I'll have to noodle on that for a minute...
    Atwater Mike, loudbang and Stogy like this.
  18. Banjo fittings. No machining needed.
    Atwater Mike, Stogy, loudbang and 3 others like this.
  19. 51box
    51box
    from MA
    @Paul Great job on these repurposed parts.
    Do you know if anyone made a 4x2 intake for a 57-8 371?
  20. Paul
    Paul
    Editor
    Yes, Edelbrock for one
    here's one belonging to a friend I had in the shop not long ago
  21. Marty Strode
    Marty Strode
    Paul, the tech, resourcefulness, the great photography, along with attention to detail, make this one of the best construction threads anywhere. The only problem I see is, you make it look far easier, than it really is ! Hot Rod Vocation.
  22. Paul
    Paul
    Editor
    I've been looking and haven't found exactly what would work here.
    Where do you find them?
    loudbang and kidcampbell71 like this.
  23. Atwater Mike
    Atwater Mike
    Paul... I had this front axle setup (chopped off wishbones, reversed hangers on V8 60 tube) and ended up welding them on the bottom (tiny bead, whew! 1959)
    Please tell me how you did yours...it wasn't in the text.
    Magnificent build, love the Olds/Buick box. (mine's a later Olds w/ '37 LaSalle)
    loudbang, kidcampbell71 and Paul like this.
  24. Lemme dig up a link
  25. Paul
    Paul
    Editor
    you mean to keep the perches from rotating?
    I posted a construction snapshot here
    and a more current shot here:
  26. loudbang and Stogy like this.
  27. Paul
    Paul
    Editor
    Whatever the thread is on a nut for the 3/16" inverted flare hard line, none of my thread gauges fit, something close to 7/16-28 but not...
    Stogy and loudbang like this.
  28. 64 DODGE 440
    64 DODGE 440
    from so cal
    Had good results from these guys, lots of fitting options and they can build hoses to fit most anything.
    https://www.bonacoinc.com/
    loudbang, Stogy, Tman and 1 other person like this.
  29. Paul
    Paul
    Editor
    Thanks man, you are a hero on this board,
    I hope one day to shake your hand.
