Projects '22 T BOBTAIL Distraction
Discussion in 'Traditional Hot Rods' started by The37Kid, May 22, 2016.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    Ive never done steel rivets before. Im assuming you have to get them cherry red before you hammer them?
  2. The37Kid
    The37Kid
    Just read the instructions, heat is recommended. Bob
  3. vanherrb
    vanherrb
    bingo
  4. hillbilly4008
    hillbilly4008
    from Rome NY
    Bob, perhaps I missed it, do you know what wheelbase you will have when all is said and done?
    I'm making more issues than progress with my 3 springer setup....
  5. The37Kid
    The37Kid
    If I follow the Fronty-Ford plans I'll have an 88 inch wheelbase. If all goes well I'll spend some time on it tonight. Bob
  6. hillbilly4008
    hillbilly4008
    from Rome NY
    I just sat and stared at mine today. Trying to decide how im going to do that front axle. I might drop down to around 90" wheelbase.
  7. Well, a few days late, but the Z is in, just need to fab gussets and grind welds. But I can say it is basically done.
  8. The37Kid
    The37Kid
    Congratulations! Nice to see someone making progress. Must be a new shop, workbench top has not become a shelf yet. ;) Bob
    brEad, loudbang, fur biscuit and 2 others like this.
  9. Kume
    Kume
    Just found this build thread. Has inspired me to get mine finished which follows a roughly similar recipe.
    loudbang, fur biscuit and The37Kid like this.
  10. A friend came over and helped get some benches built! Very useful. Moving forward. Started on the body base structure and firewall/steering column support. What did you get up too?
  11. Get going, there are 3 of us at it! (Maybe 4)...
  12. guitarguy
    guitarguy
    Better pics of the Z'ed section of the frame? Looking good. Is that a 5" drop? That's what mine is.
  13. Kume
    Kume
    pleased to see folk are still being inspired by Gerber . Here is a recent pick of my T with 27 chev spindles and hartford shocks. The build that never ends.
  14. The37Kid
    The37Kid
    What do you want to swap the headlights for?:) Bob
  15. The37Kid
    The37Kid
    Some more 1x4 and the window is trimmed, a door jamb and the outside repair is done. More stain the soffits and gutters, then restain the rest of the house. Right now it is more enjoyable than working on the car projects. :) Bob
  16. Kume
    Kume
    A pair of 8 inch Marchals
  17. Was 7”, by the time I got everything squared and level and I chickened out, went with 6”. Still get to go back and grind out and retry some of the “welds”.
    chryslerfan55, Kume and loudbang like this.
  18. ... wuss... :D
  19. hillbilly4008
    hillbilly4008
    from Rome NY
    More enjoyable? Id rather lick a truckstop toilet seat than do carpentry work...
  20. I think Bob may feel that way about doing electrical work :D
  21. ...and the front drop ended up at 6” and this ain’t Belflower
  22. The37Kid
    The37Kid
    Second generation carpenter, you got that right, looking forward to putting up the next two sheets of sheetrock, and taping the back wall. Bob
  23. guitarguy
    guitarguy
    Nice! if your using a T engine and prefer some ground clearance, 7" might have been too much. I set a pan in a chassis to find the lowest point I wanted to go--(I think it was 6" ground clearance if i remember right) Then figured tire diameter, and thusly the center distance of that that told me where my axle / spindle had to be, and the amount of drop I needed (still approximate of course). Of course midway through I changed from a T axle to an A axle. But I came out close still.
    I let the front drop dictate what the back was going to be, as I wanted them both the same drop. I took a tracing of the side of the rear portion of the rail, photo copied it a few times and started cutting it up until I arrived at all the right dimensions. I then transferred it to cardboard and marked and cut the real deal. One of the things I was adamant about was folding the top rail over vs cutting it off completely like you did. It's the small details that sometime count.
    Bob, sorry to Hi-Jack your thread.
  24. The37Kid
    The37Kid
    That Z bend looks great! Using the Chevy frame sections I have won't be as easy as I thought if I want the 88" wheelbase. I'll need to add material.
    Bob
    loudbang and fur biscuit like this.
  25. That is what I tried to achieve! You did a great job. I did have a surprise on my frame. The right hand frame rail was 3/8ths of an inch longer than the other. Drove me bonkers. There was some evidence that it might have been this way a while. The right side of the front wish bone has a gnarly kink in it...
  26. Pete Eastwood
    Pete Eastwood
    from california
    Bob , that 88" wheelbase is pretty short . Before you finalize you decision . mock it up so you can see it .
    I built my last speedster at 95 " & it was plenty short my blue speedster.jpg
  27. The37Kid
    The37Kid
    Thanks Pete! That speedster is one of the nicest period correct ones out there. How is the RAJO project and truck coming along? I've got 77 inches of the front of a T frame, really nice one with factory paint. I should just make up the back half in wood and see what feels comfortable, then make it in metal.
    Bob
  28. This is 90”, might try and roll it out side.
    alchemy, chryslerfan55, brEad and 6 others like this.
  29. The37Kid
    The37Kid
    DUNLOP tyres look nice is 1 or 3 mounted backwards?
    Bob
    loudbang, kidcampbell71 and stanlow69 like this.
  30. 1 is, why I got them for nothing. 3 big gouges out of one side of one. Also, they are at least 40 years old. Honestly, bummed. Great tires.
