Projects '22 T BOBTAIL Distraction
Discussion in 'Traditional Hot Rods' started by The37Kid, May 22, 2016.
  1. The37Kid
    The37Kid
    Marcus, since you mentioned gauges I might as well show you what I plan to use. If built back in the day you would have gone to a junk yard and found these, a 50 pound oil gauge from a MERCER and a gas pressure gauge from a STUTZ. No makers name on the hand pump, but the gas cap with the vent wing nut is a 1920's Cadillac item.
    Bob
    ct1932ford, 29EHV8, Stogy and 5 others like this.
    I'm always learning, Bob. Dig it !! :)
  3. alchemy
    alchemy
    I think the ironing board welding table is a step down from the Sears frame jig. ;)
    Cool project.
    BigO, Stogy and brEad like this.
  4. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Bob;
    I was only funning you a little, there was *no* mocking involved. The comments on everything mech were serious. I guess most folks wouldn't know that, as that is the way it was, & *could* still be. Really like the gauges, hand pump n stuff, too bad that stuff isn't readily available anymore. ;( . Hope you post lots of pics n dimensions of body n such. This is really just an earlier iteration (30+ yrs? version) of F&J's fun build. Like I said "Go Cat, GO!" :D . Marcus...
    Stogy, brEad and loudbang like this.
  5. The37Kid
    The37Kid
    I may keep the gauges & hand pump and sell the pile once the kickups are cut to shape and the frame is one solid piece.
    Stogy and loudbang like this.
  6. A Boner
    A Boner
    image.jpeg Don't see a frame kick up on your inspiration pic.....do I?
    Stogy, Lil'Alb and loudbang like this.
  7. The37Kid
    The37Kid
    No #4 may have a rear spring setup like the John Gerber car. Search John Gerber and a thread on the building of the clone will pop up.
    Stogy, loudbang and kidcampbell71 like this.
  8. Commodoreswab
    Commodoreswab
    from West TN
    I woul be interested in that Stutz gauge and I do have a comparable "gasoline" pressure gauge. I am starting to collect pieces for an Early car.
  9. The37Kid
    The37Kid
    There is a STUTZ gas tank in the classified section of the AACA website, running 1932 Fords have sold for less money in the last 12 months. Bob
  10. Commodoreswab
    Commodoreswab
    from West TN
    So basically comparable to my DR-4 mag that I got from my gpa that was a spare for his stevens
  11. The37Kid
    The37Kid
    Found a box of Hartford shocks today and one single arm with a link arm. The mate to that shock is around here some were. That pair with two arms may go to another project. DSCF9923.JPG DSCF9924.JPG
    Jet96, Stogy, tb33anda3rd and 2 others like this.
  12. rusty rocket
    rusty rocket
    I like your thought on gauges. My single seater that I am building I want to run a tach, oil,amp and temp gauge. All could be mismatched in my mind also. I have the same thought process about what a guy would have found in a junk yard back in the day. I even found a cheap set of case tractor gauges that peaked my interest .
    Stogy, loudbang and The37Kid like this.
  13. The37Kid
    The37Kid
    I'm just collecting all the parts and storing them together, may even make a note book, that way the Grandkids will know what is there and what the dream was. If I had a finished frame in primer hanging from the ceiling by Christmas it would have been a great year.
    Bob
    kidcampbell71 and loudbang like this.
  14. noboD
    noboD
    How many days is it until Bobbie gets his license?
  15. The37Kid
    The37Kid
    If the NYC Bartender left wing wacko allows cars to exist he has about 3,650 days to go.
    Bob
    46international, oj, loudbang and 2 others like this.
  16. The37Kid
    The37Kid
    DSCF9926.JPG Forced myself to do something on the project today. Finished cleaning the kickups, sprayed them with layout die, and made a template to match the T rail depth. There will be some pie cuts made to get things to mate. Looking back on the day raking 8 garbage cans worth of leaves seamed more productive.
    Bob
  17. The37Kid
    The37Kid
    This was posted in the Old Photo thread today! Got to at least move some parts around in the basement later today. Car sure has the look. Bob
    Jet96, Stogy, loudbang and 1 other person like this.
  18. cederholm
    cederholm
    This is great!!! Go! Go! Go!
    ~ Carl
  19. oj
    oj
    Wow, that is beautiful for sure, sometimes people do get it right. Is that a 'Fronty-Ford'? and what is that ribbon like belt up front by what might be a starter crank?
    Congratulations on your 15th, we're the better for it btw
  20. The37Kid
    The37Kid
    Thanks! That is a hood strap, looks like a Fronty, they must have been working on the engine the rocker cover is off. Guess the driver hopped it for the photo. Wheels are Buffalo's, notice the two T Gow Jobs on the far right.
    Bpb
  21. The37Kid
    The37Kid
    Just noticed how far back they moved the engine on this car. That stock wishbone attaches to a home made bracket and not the original socket just ahead of the flywheel part of the pan. Bob
  22. guitarguy
    guitarguy
    That was actually one of the first things I noticed looking at the pic. It also appears to me anyway that it has a split wishbone. I had to look at it for a while, but I am pretty sure it is a split (or perhaps at least a doubled up setup using an accessory bracket from the time).
    EDIT: When I said split, I really meant it had an upper and lower wishbone. I realized my terminology might have been off on that.
    48fordnut and loudbang like this.
  23. Love your collection of early parts for this project. BigO
  24. noboD
    noboD
    I think he has a new wiring harness too. Ooops.
  25. The37Kid
    The37Kid
    All four plug wires plus the kill switch. Have to box up my "To be Machined" parts. Bob
  26. David Mazza
    David Mazza
    59EA51C0-F2BE-49C1-8987-B097C551BC24.jpeg Just noticed the cars parked in the background! Look at the two early t gows/hopups! These cars were more popular than I think anyone today knows!
  27. 6sally6
    6sally6
    WOW!! Nobody's smoking a cigarette.....you sure this is an authentic picture?
    6sally6
    bondojunkie likes this.
  28. The37Kid
    The37Kid
    [​IMG]Found this photo on the HAMB old photos thread today. Bob
  29. The37Kid
    The37Kid
    I bought this bucket seat from a good friend at Hershey three years ago, spotted it in his trailer, it never hit the ground at Hershey. He bought it at one of the excess parts sales at the Henry Ford Museum.
    ct1932ford, sko_ford, BigO and 6 others like this.
  30. The37Kid
    The37Kid
    The seats in the restored Frank Kulick T race car look too new, I can only wonder if the seat I have was an original in the car. Bob
