1959 292 core Engine is complete, disassembled, checked and a good, rebuildable core. Standard bore/ crank 113 big intake cylinder heads ( ECZ-G's with larger combustion chambers ) 1.43 rockers flat top EDB exhaust manifolds manual bellhousing flywheel, pressure plate core 2 barrel intake ( Autolite 2100 ) FORD script valve covers This motor was pulled in the late '60s. Never reworked. Has original Ford bearings and hd gaskets. Have a ECZ-B 4 bbl intake for $150 extra with motor. No guessing or gambling on a core motor with this one. If you're thinking of updating your Y Block, this is a good starting point. My shop can also rebuild to your specs, and yes, I can do the oiling system mods, rework the rockers to full pressure lube and install cam bearings correctly.
