Traditional built big back window '57 pick up. 327 / 4 speed. Good magazine coverage. Literally every nut and bolt has been touched on this truck (and replaced with stainless) during it's restoration. Everything was taken down to bare metal and the frame has been boxed to the firewall. This is an all steel truck that has been painted Royal Blue using base coat / clear coat. The motor is a rebuilt '69 327. It has been bored .030 and has an Edelbrock Performer intake, 600 cfm carb, HEI distributor, headers etc. It was dressed to give the truck a 60's hot rod vibe and is very strong running. The transmission is a Muncie M-21 4 speed with a new clutch and pressure plate. The rear end is a 10 bolt with 3:36 gears and the front end is a TCI - IFS with 2" drop spindles and a Mustang II rack. It has disc brakes up front and drums in the rear. The entire system is new including lines, calipers, master cylinder etc. The wood in the bed is pine with a dark walnut stain and has about 40 coats of marine polyurethane for protection. Inside you will find high grade vinyl wrapping a chopped down Ranger seat that looks as if it were factory installed. It has a nice sound system and tilt steering wheel. All chrome, stainless and windows have been replaced and still look new. There are far too many features and details to list on this one. Located in Hodgenville, Ky Clean and clear Ky title. 270-799-8388
