Well i have decided that I'd try to send Bessie down the road to fund my other 2 projects. The title says 210 Wagon, but i have no trim. The brake system is new, the fuel system is new, the seat and door panels are new, windshield and door glass was new about a year ago. Paint is black epoxy primer. Engine is a 1969 300hp 350 with the original 041 heads. Has a comp 262 extreme energy camshaft, ram horn manifolds, exhaust back to the rear axle with thrush mufflers. It has the 1969 cast iron intake with an edelbrock carb. It's a 350 turbo column shift, stock rear end with 3.55 gears. Cragar's, great tires, rides and drives great to me (for a 1957). If you follow my build you know that it has something going on with oil pressure at idle. Dropping down under 10lbs. 50lbs out on the road. Drove the car to the hot rod reunion like this, and a couple of local shows, still runs great. I've decided to see if anybody is interested. I can use the money to build my El Camino and momma's truck. So don't be afraid to shoot me an offer, I'm sure you've all been cussed before give me a yell. Lloyd. 606-336-1997
Nice old beater. You can haul your wife, kids, girlfriend, and your buddies all at the same time. Pulling the pan back off tomorrow to change the pump. Putting a Melling M55 in it. See what happens.
