1956 Dodge c3 V8 pickup. QUESTIONS
Discussion in 'The Hokey Ass Message Board' started by omgbigdeal, Dec 12, 2012.
  1. omgbigdeal
    omgbigdeal
    Ok so for my 30th birthday my good friends went and rescued my 1956 dodge truck from the southern california desert and surprised me with it on my birthday. The truck has a V8 however I am having a heck of a time identifying exactly which motor I have in it.
    Block #1737929
    Intake #1828103 (has a 4bl Carter)
    Head Gasket #Fel-Pro 7734pt
    Cylinder Bore 3.95 inches.
    I want to know what engine obviously so I can order some parts. I have previously worked on many fords and some chevy's but this is my first mopar.
    I plan on getting this engine running. The engine turns over. I had a stuck valve but that issue has resolved. I plan to next clean up the heads, intake, and get a new carb. Any help would be appreciated.
    Teroy
  2. Rusty O'Toole
    Rusty O'Toole
    A 318 has a 3.91 bore and a 3.31 stroke. Is the valve cover scalloped along the bottom? A saw tooth design indicates a 318. It sounds like a 318.
  3. 270dodge
    270dodge
    from Ohio
    1737929 is a shared casting number, it could be a 57-301 or a 59-326 the list for 1737929 includes dodge-60-62-318,dodge-59 - 326 dodge trk .59-64,318-plymouth -57-301-plymouth 57-60,318.<!-- / message -->
  4. omgbigdeal
    omgbigdeal
    The valve covers are scalloped on the bottom. So I should check out the stroke of the engine tomorrow I suppose. That is crazy how many combinations it could be. I was thinking it was either a bored over 318 or possibly the the 326. Would the cast 4bl manifold point me any direction?
  5. George
    George
    The 301,326, & 318 are all "A" Polys with scalloped valve covers. Intakes interchange.
  6. 73RR
    73RR
    Don't let that manifold out of your sight, the A engine guys would love to have it.
    FWIW, all A series engines, 1956 to 1962, interchange as a unit. In 62 there were some changes that complicate swapping to a newer engine...not impossible, just adds some work.
  7. George
    George
    Got that right! The 2X4 is cheaper & easier to find!
  8. omgbigdeal
    omgbigdeal
    So I tracked down the previous owner of the truck and was told it has a 318 bored 30 or 40 over. The plan is to clean up the heads and intake get some new gaskets ordered find a carb and a few other things to get it fired up.
  9. Cool...and then put that sucker in a cool, light little 27 T roadster with the stick tranny.
    Seriously, I had a 55 low-box stepside and loved it.......all except for the weird brake setup. Seems I was rebuilding/replacing wheel cylinders every weekend. Mine was the little guy ..a shortbox and it had the flathead 6/ 3speed that was reliable as an anvil.
    C3 must be the 3/4 ton model, eh? Show a photo of it here.
    Here's the only photo of my old 55 I have. Too bad it's hidden behind my old 57 Pontiac in the photo.
  10. Normbc9
    Normbc9
    We had five '56 4 X 4 two door Dodge Carry-All type rigs used by the Forestry Timber Cruisers and those had the 326 in them. Four on the floor and great on and off road performance too. I wish I could find one reasonably priced to restore.
    Normbc9
  11. goon56
    goon56
    from new jersey
    i did a full resto on a 55 c3 v8. the motor was a 259 ci. poly motor. from what i found out, there were a bunch of poly motors with the scalloped valve covers. pylmouths apparently had a 270 poly around the same time. dont know the motor specs and measurements thought.
  12. goon56
    goon56
    from new jersey
  13. George
    George
    The intakes on the A Polys seal the valley, the Hemi based Polys have a seperate intake & valley cover.
