Very nicely done old school '55 Chevy. Professionally built 454, bored .40 over, Crower cam, 610 lift, 10.3-1 compression, flat tappet roller rocker arms, stainless steel valves fed with a 750 Holley. Trans is 400 turbo with 3200 stall. Ford 9 inch rear, positrac, 3.89 gear with Moser 31 spline axles. Ladder bars, 4 wheel power disc brakes with auxiliary vacuum pump and tank, power steering. Hooker headers with 3inch true dual exhaust with Flowmasters. Tires are all new and mounted on Weld wheels. Interior is excellent, trunk is finished out. Body solid, all steel, with a very good paint job. Very good car, will drive around town nicely and then turn into a beast when you want it to.
