For sale is this set of cylinder heads that came off a 1955 Dodge 270 Hemi. These will fit on the 241 Dodge Hemi blocks as well. They will also fit the 1954 1955 241 and 270 Poly blocks. Included in this sale are the intake, exhaust valves and springs and valve keepers, that have been cleaned up by the machine shop. The are the same ones that came off these heads, they are used, not new. (new valves typically cost $175-$200 for each set) Inner and outer springs can run $135-$150 per set. So if you're looking for a budget build this may be what you need. Casting number on the heads: 1554132 ** The heads have been hot tanked, media blasted and magnafluxed, no cracks. There will need to be some work done around the valve seat area on a couple of the intake/exhaust ports. Each heads weighs around 62 lbs. each, they will be shipped separately and I will put the valves and springs in one of the boxes with the heads, so that one will weigh a little more. $450 for the set
