Projects 1952 Pontiac Catalina Hardtop Build
Discussion in 'Traditional Hot Rods' started by 1959Nomad, Sep 8, 2021.
  1. Bird man
    Bird man
    from Milwaukee
    I love the way you are headed with this, factory knob on an aftermarket switch for instance. The car has found a good home. The gas tank "cradle" seems like a clever solution but how fortunate the the correct tank is available. Now what you need is a pair of the aluminum chebby heads with the Pontiac logo on them :) Or if you need a Pontiac straight 8, look me up!
    loudbang and Bruce A Lyke like this.
  2. Thats a nice looking car for sure......BTW the the rear wheel spats look almost identical to those used on 1949-52 Chevs, at least here in Oz anyway and should have a rubber seal or gasket between the spat and the body, I was able to get these seals from Steele Rubber....also you mention that the car had a sun visor........the 41 Plymouth I had I obtained and mounted a Fulton 1000 Series Visor which had come from a 1948 Plymouth it was on in the USA however my understanding is that the 1000 Series Visors were used more into the early 50's so that might be worth checking out......my personal preference was for this type of visor as it does not have the "wooden plank" look of a lot of the visors used and suits the more rounded "streamlined" early 50's styling......see pic of my Plymouth, since sold, also larger stainless steel reinforced centre bracket...........anyway thats a nice hardtop you have.............regards from Oz......andyd
  3. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Nice going . Just got here. A nice car gets a great surgeon.
    Funny, when saw the tank mount I figured, 'That's why guys get accused of not asking for directions'
  4. Bruce A Lyke
    Bruce A Lyke
    Thanks Guys!
    BTW, Like the "Surgeon " moniker:cool:
    Even if I'm figuring most of it out as I go:rolleyes:
    loudbang and Tow Truck Tom like this.
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    You are no butcher!
  6. Bruce A Lyke
    Bruce A Lyke
    Progress continues, decided to rip out the remaining firewall insulation which was pretty bad shape.
    This made it a lot easier to finalize the location of new Heater/Defroster
    Will clean up the rust and put something on the firewall to help with heat and noise.
    PhilA and loudbang like this.
  7. Bruce A Lyke
    Bruce A Lyke
    So here are a few more updates
    - Finished the plumbing for the heater
    - Started on plans for a 3RD Rear light, using the same type that was in the Nomad
    - Made a glove box out of an old file box i made in the 70's
    - Added a set of headlight visors.... Just for fun? (Or do they help keep the car "Cooler" in the summertime?)
    Ford52PU, guthriesmith and loudbang like this.
  8. Bruce A Lyke
    Bruce A Lyke
    Pretty happy with the way this will work out:cool: 3rd Light.jpg
  9. Bruce A Lyke
    Bruce A Lyke
    Happy to say the wiring for interior lights and switches has been sorted out and is now ready to go.
    It’s toward the end of the rewiring list since it is not “necessary”. There was not a lot to start with as much of the existing wire and parts were gone or needed rework. To figure out how to get 4 lamps and 4 switches to all work in harmony a lot of jumpers with alligator clips were used. Only 2, 15-amp fusses were blown. Discovered there is a back seat switch for the lamps, its on order and will just need mounting on the rear driver's quarter panel cover. Made my own larger schematic to check off parts of the circuits as they were confirmed.
    Also have a functioning Neutral Safety switch mounted under the car to the TH400, Reverse light switch and Kickdown switch. I will spare the details unless someone needs to know the process used.
    Wiring and sensors for the oil and water temp are next
  10. Bruce A Lyke
    Bruce A Lyke
    functional lighting at last :cool:
  11. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Very nice Bruce!
  12. Bruce A Lyke
    Bruce A Lyke
    Finally, :cool:
    it really took a lot of other work to get to where I could hook up 2 wires for the back-up lights Back up Lt.jpg
  13. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Looks good Bruce! And, nice tag topper. :D
  14. Bruce A Lyke
    Bruce A Lyke
    Mount 3rd LT.jpg 3rd Lt Done.jpg Completed the mount and installation of the 3rd brake light in rear
    Almost done with the wiring
  15. Bruce A Lyke
    Bruce A Lyke
    Dash Lights.jpg Hood LT.jpg Hit a milestone today in getting all of the wiring and related work done.
  16. Bruce A Lyke and guthriesmith like this.
  17. Bruce A Lyke
    Bruce A Lyke
    Did a quick comparison to remind myself of the before and after :cool: wire B4.jpg Wire after.jpg
    bchctybob, brEad, PhilA and 5 others like this.
  18. Johnboy34
    Johnboy34
    from Seattle,Wa
    Nice! You're taking that poncho to a new level!
    Bruce A Lyke and loudbang like this.
  19. arkiehotrods
    arkiehotrods
    Looking great, Bruce!
  20. Bruce A Lyke
    Bruce A Lyke
    Getting the Car ready for spring and summer.
    Cleaned the interior with an upholstery cleaner
    Installed the seatbelts
    Reworked the passenger side wheel opening to properly fit the skirt
    Hopefully today's rain will get the roads pretty well washed off.
    brEad, olscrounger, PhilA and 3 others like this.
  21. Bruce A Lyke
    Bruce A Lyke
    New plates will make it easier to know if it is my car or a different 1952 Pontiac Chieftan Super Deluxe Catalina :cool:
    Also removed the "H" Guard in the rear, like the simpler look better
    olscrounger, PhilA and guthriesmith like this.
  22. PhilA
    PhilA
    Looking real nice, you've done it justice.
    I agree on the excess chrome frippery too. Looks better without.
    Phil
    Bruce A Lyke likes this.
  23. Bruce A Lyke
    Bruce A Lyke
    Good to be at the point where there is time for the "Nice to have" upgrades
    Made a dual drink holder
    guthriesmith likes this.
  24. greaser 35
    greaser 35
    from FRANCE
    Good job on your car !!!
  25. Bruce A Lyke
    Bruce A Lyke
    Guess it is time for a bit of an update, have had the car out several times when the weather was cooperating.
    replaced the old original Speedometer cable and it seems to be very steady and accurate now, hopefully it will stay that way.
    The TH400 Kickdown seems to shift as it should, and the Quadra-jet Secondaries also seem to operate properly now that the vacuum lines have been sorted out....
    However, when it is floored to WOT and the RPM's are getting pretty high, there is a bit of a high pitched whining sound. let up on the gas, it upshifts and its fine. anyone familiar with this sort of thing?
  26. PhilA
    PhilA
    Can't help on the whining noises, but I did find that my wheel skirts would rattle- I just cut some thin rubber tube and stuck it over the legs where they slot in. That snugged them up nicely.
    Phil
  27. Bruce A Lyke
    Bruce A Lyke
    My Skirts still need to be painted and then put on. Did buy the proper seals for when they are ready to go on.
    brEad likes this.
  28. Bruce A Lyke
    Bruce A Lyke
    No new pictures but I have been driving the car around the area. Today I drove our Grandaughters to thereir schools at the request of the 13-year-old
    PhilA, 51pontiac and guthriesmith like this.
  29. Bruce A Lyke
    Bruce A Lyke
    Well, the initial shakedown process is complete, and the Catalina should be ready for the summer and increasingly longer trips. Drove it to the store today, went on the highway and repeatedly verified the TH400 would dropdown to low and take off:cool:. The squealing was the fan belt slipping at WOT and found some helpful information here on that.
    painting the fender skirts is the next larger task, but it is in the nice to have category:rolleyes: 52 at FF.jpg .
  30. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Glad to hear you are getting it all sorted out Bruce! Neat car for sure! :cool:
