1951 Nash Rambler Build Thread
Discussion in 'The Hokey Ass Message Board' started by D_Lazaris, Oct 11, 2010.
  1. D_Lazaris
    D_Lazaris
    from So. Cal
    I've checked these guys out, pretty crazy stuff. I am really tempted to buy their potvin setup for flathead ford... Haha
  2. D_Lazaris
    D_Lazaris
    from So. Cal
    I got the support bracket on. I used an existing bracket in my scrap pile and with little modification it worked PERFECT!!!
    I also began the vacuum lines for the vacuum switch. Next will be the spacer plate between the carb
  3. 64 DODGE 440
    64 DODGE 440
    from so cal
    Loving this build...and those plug wires are period perfect!:D
  4. D_Lazaris
    D_Lazaris
    from So. Cal
    Thanks!!! I'm trying to do all the wiring in cloth... it just feels right!
  5. bonez
    bonez
    from Slow lane
    Comin out nice!
  6. D_Lazaris
    D_Lazaris
    from So. Cal
    Thanks!
  7. D_Lazaris
    D_Lazaris
    from So. Cal
    I did some research and it looks like my supercharger is an older model. The VS57A, VS57B, and VS57C were the first models produced. I have the C model. But with that the solenoid on the supercharger is 6volt with the older models. I won't be able to check until tomorrow but it's good I caught this ahead of time, since it's such an easy fix (they suggest using a voltage reducer, rewiring can be done though) would of hate to burn out the solenoid!!
    But maybe it was converted already? Or since it was one of the last "older" models maybe it came 12v? We shall see...
  8. 64 DODGE 440
    64 DODGE 440
    from so cal
    Careful...you might let the smoke out of the wiring harness. :p
  9. Domino
    Domino
    This is going to be a really cool ride. You don't see too many people working on a 51 Nash and here you are supercharging one. That is just too cool.
  10. D_Lazaris
    D_Lazaris
    from So. Cal
    So, I was able to get another stock carburetor for the Nash, so that should be coming in next week.
    Where can I get a full rebuild kit for the carbs? (Not just gaskets, but floats, jets, ect.)
  11. plym_46
    plym_46
    from central NY
  12. D_Lazaris
    D_Lazaris
    from So. Cal
  13. plym_46
    plym_46
    from central NY
  14. D_Lazaris
    D_Lazaris
    from So. Cal
  15. D_Lazaris
    D_Lazaris
    from So. Cal
    After a week of anxious waiting the carburetor finally came in!
  16. D_Lazaris
    D_Lazaris
    from So. Cal
    Got the air cleaner mounted. Curious to see how much room there will be in the engine compartment. I'm 98.5% sure it will fit!
  17. plym_46
    plym_46
    from central NY
    just a thought, if that is one of those 4 inch paper filters. they are notorious for not flowing a much air.
  18. jdanielshea
    jdanielshea
    from Denton, TX
    I'm late to the party, but where did you find the head. Would like the same or similar for the 196 in my '63 Rambler.
  19. Dave K
    Dave K
    the heads pop up on ebay
  20. Sheep Dip
    Sheep Dip
    from Central Ca
    Hell Yah! Get after it...love the engine color choice's, keep us posted.
  21. D_Lazaris
    D_Lazaris
    from So. Cal
    Yeah I got mine on ebay.
    I've only seen another one on ebay within the last year.
  22. jdanielshea
    jdanielshea
    from Denton, TX
    Hey GI,
    What'd you have to pay for the Edmunds head if I may be so bold as to ask!
    Thanks,
    Dan
  23. D_Lazaris
    D_Lazaris
    from So. Cal
    I payed $250 for mine, I thought it was a decent price. (plus it was never used)
  24. Richard/SIA
    Richard/SIA
    from No. Nevada
    As many 3-2's guys have found out, that air filter is good for a 15 HP penalty!
    No point to a blower if it's coupled with a major restriction like that.
    You want a free flowing intake, you are trying to INCREASE air to the carbs, try to keep it as cold as you can too.
    Maybe you can hide a free flowing oversize filter behind the grill, or in a fender, and run a hose to the supercharger intake?
    Keeping the intake charge as cold as possible is important, compressing the air heats it, too hot = pre-ignition issues.
  25. awsome thread chap.....loving the engine work so far. My 51 Nash Rambler had a 2ltr injected Pinto lump and 5 speed manual box...used it as a daily for a year and regret selling it...mine was a full kustom pick up with fender skirts both front and back..[​IMG]
  26. farna
    farna
    Paul, you wouldn't happen to have any underhood shots would you??
  27. D_Lazaris
    D_Lazaris
    from So. Cal
    Yeah I know bout how restricting the air filter is.
    I am trying to keep if period correct so I don't want a k/n air filter which would be the best though...
    And I didn't want to hide one. What would be the best?
  28. D_Lazaris
    D_Lazaris
    from So. Cal
    Love it!!!!!!
  29. Richard/SIA
    Richard/SIA
    from No. Nevada
    If it were me, I would find a correct looking canister type.
    The Air Silencer from a 60's Jag sedan springs to mind, a lot of them are bullet shaped with a removable end cap.
    Not too hard to find.
    And the filter would not be visible, so you could have the K&N.
    I think it could be made to fit in the engine compartment and still look good.
  30. D_Lazaris
    D_Lazaris
    from So. Cal
    I will look into that!
    Now I've always thought that the canister types were more restricting. What makes them better?
