Technical 1951 Dodge 3/4 ton truck rear axle
Discussion in 'The Hokey Ass Message Board' started by Joe Coughlin, Aug 9, 2016.
  1. Joe Coughlin
    Joe Coughlin
    Hi, does anybody know anything about the rear axles and seals on a 1951 dodge 3/4 ton. Its a full floating rear axle with a seal that goes on the end and seems to prevent oil from the axle feeding the wheel bearings. I can't see any way of filling the hub with oil. Any help would be appreciated. Thanks
  2. proartguy
    proartguy
    from Sparks, NV
    There should be pipe plugs to remove for filling with wheel bearing grease. The book says it takes 1/2 oz.
  3. Joe Coughlin
    Joe Coughlin
    So the bearings require packing with grease before installation then. I didn't spot any pipe fittings in the hub to fill.
  4. 302GMC
    302GMC
    from Idaho
    That's it, Joe, packed with quality grease they'll last a lifetime.
    Joe Coughlin likes this.
  5. proartguy
    proartguy
    from Sparks, NV
    image.jpg I was going by the info in the owners manual. Maybe the don't all have plugs.
  6. Joe Coughlin
    Joe Coughlin
    I had a look and definitely no plugs on the axle. Packed them up with some good great and got them back together. Was driving the truck this morning but I'll pull the half shafts and check them in a month or two. Thanks for the help
