-SBC 350 w/ finned aluminum valve covers, newer intake, new distributor, new aluminum air filter, new spark plugs etc. -Fresh built 700r4, less than 500 miles. -New driveshaft -Posi rear end, 3:73 gears. -Headers with dual straight pipes. -New aluminum radiator, has standard fan and auxiliary electric fan with a switch on the dash. -New disc brakes up front -Steering was rebuilt to new. -Rebuilt original gauges. -Full air ride suspension with 7 switches, lays frame. 4 link, c notch and the whole deal. -Radial wide whitewalls from Diamondback Tires wrapped around stock wheels with hub caps and trim rings. -Paint is excellent and extremely straight. Painted by HUB auto body in Saticoy, CA, it is a 1963 Impala Autumn Gold body with a White/Cream top. -All stainless trim is original and has been straightened and polished. Original grill, straightened and chromed. -Original steering wheel, painted. -One piece bumpers, original 1951 license plates that have been restored. Most chrome pieces are original and have been straightened and rechromed. -All of the glass and every piece of rubber on the car is new. New sound system installed with bluetooth, 2 6x9 speakers hidden under the dash, 2 4x10 speakers, 10" sub woofer and amp hidden under front seat. -Full custom interior by the famous Nelson Kustom Upholestery, two toned to match the paint. Underneath upholstery is 2 layers of fatmat insulation. -Insured for $40,000 Probably forgetting stuff, but everything is done and new, turn key car that cruises on the freeway at 75mph with no problems. I have all the receipts for the work done. I wouldn't hesitate to take the car anywhere, built to drive and to show. Almost all of the work was done by NOBLE FABRICATION, the best custom shop in the world, if you don't know then do your research. (310) 702-6356
