Up for sale, I have a very nice 1950 Dodge pickup .. This old pickup has never been wrecked and has no rust, other than the Panina you see on it, the frame is in perfect somdition. The pickup has been rebuilt using NOS parts where applicable, from front bumper to rear bumper. I think this list covers most of it .. Engine is the original Flat Head 6 Complete engine rebuild, performance camshaft, new pistons and rings, new valves, and valve guides, head was milled, block maged. Install new water pump Convert coil to electronic coil (remove points and rotor) Install new radiator (oversized) Rebuilt fuel pump Install new fuel line w/inline filter Rebuilt carburetor Transmission T5 Transmission (Chevy S-10) rebuilt, new brearrings, and synchros New clutch, pressure plate and TOB Suspension Dropped front axle (3 inches) Reversed Eye on Front Springs (1 inch) New front spring bushings New shocks (all 4) Brakes Conversion to dual chamber master cylinder and brake pedal assembly Install all new brake lines Front brake conversion to disk brakes Replace rear wheel cylinders and install new shoes and spring kits Rear-End New bearings and seals. New driveshaft Wiring Convert to 12-Volt system Install all new wiring harness Install turn signal switch with indicator lights Instrument Panel Refurbish original instruments (speedometer, oil pressure, amp meter, temperature, fuel gauge) Install new instrument cluster and gauges (voltmeter, oil pressure, temperature) Glass All new glass (front windshield, side glass, and back glass) All new rubber seals and felt Interior Interior painted Reupholstered bench seat Install heat barrier to cab Tires/Wheels New Goodyear radial tires Powder coated original rims New hubcaps Lighting Install all new head lamps, turn lamps, and rear lamps Install new rear light assemblies General Information 3rd Owner of vehicle. 2nd Owner purchased in 1970. Odometer showed 70K miles. Truck was running and driving at time of purchase. Competed an extensive mechanical restoration and converted various components to make an everyday driver
