Projects 1950 Chopped Chevy Sedan Delivery
Discussion in 'Traditional Customs' started by RMONTY, Jan 15, 2016.
  1. RMONTY
    RMONTY
    Let's see how your vents look! Or will you be at the show next weekend?
  2. Yes, I intend to be at the show next weekend with the Chevy, but for the sake of answering your request here in the thread, this is what I got at the moment:
    My intention is to make the whole front of the record player flip down rather than the using the flip up door....that gets in the way of the air getting up to your face. Making the whole front flip down I can make a plate for the vents to mount in up at the top half and have a bit of a glove box/shelf at the bottom since the glove box is gone now with the ac unit there of course. Also, I used the slider switch deals Vintage Air makes for 64 Impalas to convert the factory heater control to run the ac. There was an article in Custom Rodder (I think) years back using those to convert the 49/50 Chevy heater switch to help hide all this stuff. Works great. I know the 51/52 Dash is different, so I don't know what that heater switch looks like, but I throw it out there if it's something you wanna mess with. I'll be using the same VA pieces to do the Merc heater controls.
    40two, brEad, Hombre and 2 others like this.
  3. RMONTY
    RMONTY
    Great stuff Dave. I hope to see you at the show. I'm coming in on Friday night.
    I have a really nice 51-52 set of slider controls that I am going to be converting to work with the VA slider switches. I have a great resource in the guys that sold me the unit, Sachse Rod Shop over in Sachse TX. Mike over there has been great and he has gone over the install with me time and time again to make sure I get it right. He is going to assist me in making up the line set for the install as well. I am anxious to get the mounts in place so I can wrap up painting under the dash. I need to start getting the little unfinished parts of the project knocked out 1 by 1.
    brEad and drdave like this.
  4. It's exciting when the little pieces start lining up and suddenly a big chunk can get done and bang!....look ma, that looks like progress! :)
    RMONTY and Okie Pete like this.
  5. cabong
    cabong
    B Bay Barn and drdave like this.
  6. RMONTY
    RMONTY
    I got some work done this evening. I got the Vintage Air unit mocked up and brackets made. It's a slick unit for sure! I also mocked up the Newport Engineering electic wiper motor to be sure there was no interference. I'll take it all back out now and paint under the dash with epoxy primer and then white paint. Starting to gain a little momentum here......
    20220831_191114.jpg 20220831_204008.jpg 20220831_204016.jpg 20220831_204047.jpg 20220831_204105.jpg 20220831_204120.jpg 20220831_204127.jpg 20220831_204132.jpg 20220831_204328.jpg
  7. RMONTY
    RMONTY
    Its been awhile since I have posted here so I thought I would make an update. Today was a good day for my car, and for me. I recently had a quadruple bypass back on Feb 17th and have been trying to get back to doing the things I enjoy. Sundays is usually Car day when @trevorsworth drives over from Weatherford and lately we have been working on his Model T project, before I had to take a break for the heart surgery.
    Well today we rolled the Sedan Delivery out into the driveway and decided it was time to get some things done to it. I had started building the brake system on this car years ago, but never put brake fluid in or bled the brakes or adjusted the new emergency brake cable system I had installed. I had bought a dual master cylinder from O'reilly's that had a lifetime warranty and built a bracket for it from a thread I found here on the HAMB. The master cylinder had at some point gotten a lot of moisture in it and was quite rusty inside, so I had a friend pull it out for me a week or so ago as I am not quote ready to crawl under the car, and I went and exchanged it for a new one. Trevor and I had to modify it a bit as they didn't have an exact replacement, so we got that done, and installed it. We started priming the system and there were a few fittings that leaked due to not being seated properly, or not tightened at all when I bent and flared all the lines up back several years ago, but within a couple of hours we had good brake pedal and had bled all the lines and still had great pedal. We need to modify the pushrod and adjust the emergency brake cables and rear shoes to complete the work but for all intents and purposes I now have a working brake system.
    While I have been recovering I started fooling around with the 235 six banger engine that has been sitting for years with a dual carb setup from Tom Langdon and the engine had never been fired up, so I checked everything over really well, and hit the key on the stand that I had built for break-in of the engine, and that bad boy fired right up! It appears to be ready to be dropped in the car, so I have a few things to do first, like heal up for a few more weeks, and that is going to happen. I will try to post up a video of the engine after bit.
    It was a great day for me, and thanks to Trevor for helping me with it. It wont be long before I drive this car, even if it is around the pasture here!
    OahuEli, SS327, hfh and 16 others like this.
  8. Glad to hear you are healing up and back on the car! :cool:
    RMONTY and Kroombit like this.
  9. Damn brother, glad you're up and at it! Not so glad that you had to go through all of that though. Looking forward to your progress, since mine is nonexistent lol
    OahuEli, RMONTY and Kroombit like this.
  10. Lone Star Mopar
    Lone Star Mopar
    Dang bud thats heavy stuff...
    Glad to hear you're on the mend and able to do some things you enjoy.
    RMONTY likes this.
  11. The37Kid
    The37Kid
    Glad you back at it, I really like this project. Bob
    RMONTY likes this.
  12. RMONTY
    RMONTY
    It's a good thing they found what they did when they did, as I didn't have a major cardiac event like a stroke or heart attack. Got the plumbing all taken care of so I'm ready to rock and roll for a lot more years with good health as long as I do the right things!
    40LUV, SS327, drdave and 8 others like this.
  13. trevorsworth
    trevorsworth
    There's a strange synchronicity in getting both your plumbing and your car's plumbing sorted out at about the same time. I can't wait to get that six slapped in there!! It sounds crazy good.
  14. 1-SHOT
    1-SHOT
    from Denton
    Glad to see your back was wondering what had happened to you and Trevirsworth had not seen any post in a while take time to heal. Frank
    RMONTY likes this.
  15. RMONTY
    RMONTY
    Made some more progress today. Trevor had the day off so he made his way over to the house. We set the engine/transmission into the car, and bolted it to the motor and transmission mounts, and hooked up the clutch to make sure there wasn't any interference with the new Heim joint we put in the master cylinder for the brakes. All is well, got a measurement for the drive shaft and will get one made up in the next few days. Closer and closer to driving this old heap. I decided a while back I want to drive it before I make it pretty. It may not ever be pretty with all the rookie body work, but I'll drive the wheels off it!
    20230322_161213.jpg 20230322_161155.jpg 20230322_161145.jpg 20230322_161129.jpg
  16. trevorsworth
    trevorsworth
  17. Just remember, they all look good at 60 MPH. No one really knows what they are looking at but it's Kool.
    Hombre, SS327, drdave and 2 others like this.
  18. RMONTY
    RMONTY
    Here is a shakey video clip of the engine running with the dual carbs.
    Okie Pete, Hombre, SS327 and 9 others like this.
  19. RMONTY
    RMONTY
    You've been a great help and kept me inspired on this long project sir, and I cannot tell you what that means to me. But this IS finally happening!
  20. patsurf
    patsurf
    well,bolt 2 fenders and a hood w/ some baling wire--do a yard drive when you get that driveshaft!
  21. I will say you had your hands full. Good Job!
  22. RMONTY
    RMONTY
    I've got a complete assembled front clip going on in the next few weeks for just that purpose!
  23. Well you just keep on keeping on. Those six’s just sound so good.
    RMONTY likes this.
  24. Dang skippy
    RMONTY likes this.
  25. Very kool! :cool:
    RMONTY likes this.
  26. RMONTY
    RMONTY
    Hey Dick! Good to see ya! When I get this heap on the road I'll give it a shakedown run over to Arlington and buy you a cold beverage of your choice!
  27. Man! Sorry to hear about the ticker, but glad you caught it and got it all taken care of before there was an issue!
    Truck is looking great! So excited for ya! You’re gonna like those carbs…I’ve been real happy with them on mine. Looking forward to catching up with you in a few weeks at the SK
    guthriesmith and RMONTY like this.
  28. RMONTY
    RMONTY
    Thanks man!
    Looking forward to it as well Dave. I have tickets to the Tedeschi-Trucks Band concert the night before in Dallas but will get up early and drive in on Saturday morning and probably spend Saturday night before driving back, kinds depends on what my stamina is in early May. It's a 4 hour drive one way. But either way I'll see you on Saturday.
    Okie Pete, drdave and guthriesmith like this.
  29. hillbillyrabbit
    hillbillyrabbit
    This is great brother. It gives me fire as well. I am super stoked that you are going to be at SK this year. I will see you and Dave there.
    drdave likes this.
  30. Man, SK will kinda like a family reunion...like always. :D
    Okie Pete, drdave and RMONTY like this.
