Real nice '48 f-1, 1/2 ton. Cab is a '51 the rest of the truck is a '48. perfect frame, 351w ,new rings,bearings,oil pump,water pump, timing chain ,sprocket. New high lift cam,new 600 edelbrock, new direct fit superior aluminum radiator 3, 1/2 gal. capacity.c-4 ,lokar swan shifter, disc front power brakes(LMC power booster /master cylinder and portion/metering valve, lowering leaf springs front and rear, dual Porter mufflers, new rebel wiring kit,1957 f-100 9'' rear 375 gears,separate tri gauges(oil,temp,volts) new tires, nice f-1 steel rims, 5/5.5. Usually rust spots were cut out and replaced with metal . New gas tank & sending unit. transferable title in my name. Lots of other goodies I probably forgot to list. She's fast , steers and stops on a dime. Priced for quick sale.... first $14,500..OBRO(or best reasonable offer) ...takes her home..... pm me.........
