1948 Chevrolet truck 3/4 ton questions
Discussion in 'The Hokey Ass Message Board' started by RUSTEE 57 GMC, Dec 31, 2010.
  1. RUSTEE 57 GMC
    RUSTEE 57 GMC
    from Tennessee
    Hello,
    I have purchased a 1948 Chevrolet truck. It is what I believe to be a 3/4 ton because it has 8-lug wheels on it. It has no bed on it. Does all this Info mean it is a long bed truck only or could it have come factory with a shortbed too? I have measured the best I can come up with it somewhere around 124" inches from the center of the front wheel to the center of the back wheel. It still has the 6 cylinder engine in it with the 4-speed trans. Would that engine be a 216 or a 235? I am not familiar with these trucks so any Info about this would be appreciated. I am hunting for a bed for it but do not know what size to get. Long or Short? Thanks for the Info in advance!
  2. Ghostrider
    Ghostrider
    Wheelbase should be 125.25". All 3/4 tons had the same wheelbase and the same length bed.
    Original engine would be a 216.
  3. 3 stake pockets on each side of bed,= 3/4 ton
  4. RUSTEE 57 GMC
    RUSTEE 57 GMC
    from Tennessee
    As stated in the first post about the truck, the truck has no bed on it. Does this mean that it is a long bed that is suppose to be on it?
    Thanks for all the info!
  5. 302GMC
    302GMC
    from Idaho
    Engine is 216 unless it's been changed. Hood trim still there ? 3600 is 3/4 ton, 3800 - 1 ton. Serial # will have FR for 3/4, FS for 1 ton. If you find a box on a GMC, make sure the fender will end up in the right place.
  6. RUSTEE 57 GMC
    RUSTEE 57 GMC
    from Tennessee
    Thanks for the Info. No hood trim. It has been removed over the years I guess. I can see where it was supposed to be though and I am sure it has the original engine. So a 216 it is then. It does that the Day and Night rearview mirror and cigarette lighter. Anything else you could tell me about it is appreciated. I would still like to know if it supposed to be a short or long bed truck or not.
  7. Steve Ray
    Steve Ray
    If it's a 3/4 ton it's most likely a longbed with a wheelbase of 125.25". Original engine was a 216, but many have been upgraded to a full-pressure 235. A 4-bolt valve cover indicates a 235, a 216 will have two center bolts holding it on.
    Here's a link: http://auto.howstuffworks.com/1947-1955-chevrolet-trucks1.htm
  8. 302GMC
    302GMC
    from Idaho
    The box should be 8 1/2 feet long.
