Im thinking of using one on my car, but before i drop some change, can anybody give the measurements of one? Height, width of top and width of bottom.. Thanks!
54.3" (1380mm) wide (Outside tips lower bar) x 12.9" (330mm) tall (Bottom of lower bar to top of upper bar)
You're right, that does make it look smoother! I really want one of these grilles, and they seem to be almost the perfect size
Yep, exactly. Mines a '47 and I took mine out. Denny Leske from the Ionia Hot Rod Shop welded the holes in the pot metal pieces and Advanced Plating in Nashville then replated the grill for me. I couldn't be happier with the look. REALLY makes the front end flow.....nothing breaking up the lines. Worth the time, effort and money.
Well, it definitely isn't the stock one! Don't know if it's aftermarket, though. Could be a custom made one. Maybe she will chime in and tell you where it came from.
ironically i didnt like them when I did my car the first time around.. but.. they are in fact stock..
