I have a 1947 Ford 1.5 ton truck. It needs a bed. I found an old man that had his own lumber yard and he has a bunch of lumber left over. He has 12 long 2 thick by 6 wide planks that were cut years ago that were left on the back of a flatbed truck. The wood is straight and level and it has this great gray color to it. So Im going to buy enough of that wood from him to make a flat bed for my truck (210 + linear feet). The bed will be approx. 12' long and 7' wide. Im wondering if I should build a head board for the bed or just butt it up against the truck cab? Anyone have $0.02 or pictures to share? thanks
If you want to acctually use the truck, you need a head board, so your cab wont get crushed. Depending on what you want to haul, the headboard does not need to cover the entire back of the cab. What kind of wood is it???
I would definitely install a headboard. Another suggestion would be to make removable sideboards similar to this COE.
Here are some pictures of a '48 with a wood bed. The truck is forsale if anyone is interested. http://www.jalopyjournal.com/forum/attachment.php?attachmentid=260088&d=1167855802 http://www.jalopyjournal.com/forum/attachment.php?attachmentid=260087&d=1167855802
If it's rough cut saw mill lumber, to do a 7'x12' area would take 14 planks at 12' length or 168 board feet of 2x6. If you do any trimming you'll lose the grey pitina for awhile. Should use Oak for the bed. You'll need some 4x4 for cross supports. Stick with the rough cut from the saw mills and any wood you buy will only be about 1/3 what you would pay at Lowes or Home Depot. I just got, from a local saw mill, 5/4"x6"x12' for $2.08 a board, enough to do a 10x12 floor $41.60 total cost.
