1946 Ford Convertible Project Has stock frame with new tubular center section (J.W. Rod Garage) and trans mount to be installed. Extra set of outer frame rails to be used for boxing. Firewall mount brake pedal assembly ( J.W. Rod Garage) not installed. Southern Rods Mustang II front end assembly tacked in place. Has 2" dropped spindles, 11" disc brakes, tubular control arms, & power rack. Chassis Engineering rear parallel leaf spring assembly installed with shocks and sway bar. 96 Ford Explorer 8.8 disc brake rear with 3.73 posi. Stock body and front clip. Has 47/48 fender extensions without turn signal holes. Fender trim holes have been filled. Inner and outer rockers replaced with Bitchin parts along with floors and toe boards. All other rusted pieces have been replaced and smooth running boards installed. Body has stock steering, dash, gauges, radio, antenna, gas tank, radiator, power top, heater, and trim. All exterior trim is included and in excellent condition. Front and rear bumpers with brackets and gravel shields. Front and rear seat frames, Rear side panels and garnish moldings front and rear. Side windows with regulators, wing vents, & zip out rear window. No windshield but have center divider. No engine or transmission. Car is in light primer with no body work started. Asking $14,200.00 Will Trade up or down but no projects View attachment 2840534 View attachment 2840534
