1941 Dodge Luxury Liner Custom. 1. Fuel injected TBI 350 with less than 80k on it. 2. Power steering-Thunderbird rack and pinion 3. Power brakes 4 wheel disc 4. 700r4 transmission 5. 7.5 Mustang rearend 6. New upholstery (need headliner) 7.1959 Impala Dash and Steering column. (all gauges work except odometer) 8. New Firestone wide white walls (Speedway motors hub caps) 9. New aluminum radiator 10. New flex fan 11. New brakes 12. New leaf springs 13. New fuel pump and sending unit 14. New auto meter gauges 15. New complete route 9 wiring harness 16. New floor, Channeled over the frame 7inches. 17. Front frame is cut and boxed for the thunderbird rack and pinion. 18. Rear air shocks with a valve in the trunk to raise the ride height a bit. I did not do the work myself, but I have driven this car far with no issues. It is not perfect, there are some oil leaks and trans leaks, but nothing from stopping it from going on long drives. All the windows are in good shape but the rubber is dry rotted except the rear window(it is new rubber). Runs drives and stops with no issues, does not overheat. You CAN take this on long drives! 12K obo 20180901_153754 by bungle posted May 9, 2020 at 5:36 PM 20180901_153916 by bungle posted May 9, 2020 at 5:42 PM 20180624_082343 by bungle posted May 9, 2020 at 5:42 PM 20180901_154104 by bungle posted May 9, 2020 at 5:42 PM 20200414_141816 by bungle posted May 9, 2020 at 5:42 PM 20200414_141831 by bungle posted May 9, 2020 at 5:42 PM 20200414_141847 by bungle posted May 9, 2020 at 5:42 PM 20200414_141922 by bungle posted May 9, 2020 at 5:42 PM 20180624_081900 by bungle posted May 9, 2020 at 5:42 PM 20180901_153829 by bungle posted May 9, 2020 at 5:42 PM 20180627_121225 by bungle posted May 9, 2020 at 5:42 PM
