Customs 1940 Ford Sedan: “Family Truckster” Build
Discussion in 'The Hokey Ass Message Board' started by JohnnyCASHcadillac, Feb 7, 2020.
  1. I remember seeing those on a 40 chassis I did for a friend a while back. Don't know what they're for off-hand, but I just hammered them flat.
  2. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Rear on both sides where the X member joins
  4. alchemy
    alchemy
    Is it a mounting point for the '38 cable brakes? Is that the original frame for that car? Maybe Ford never changed the stampings.
  5. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Rear end is set.
    Posie set up was pretty straight forward without much in the directions.....
    brEad, 35cab, kidcampbell71 and 9 others like this.
  6. Zax
    Zax
    1. 1952-59 Ford Social Group
    The rear shackle looks like it does not have much travel before it would hit the frame. But it may just be a bad angle on the pic.
    Thor1 and loudbang like this.
  7. poco
    poco
    from oklahoma
    The bump is where the e brake cable runs through.
    loudbang and Thor1 like this.
  8. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I’ve jumped up and down on the rear and nothing hits.
  9. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  10. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  11. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  12. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I heard of a trick to get the headers to fit. Switch the passenger and driver headers to avoid the steering box. Luckily I had an extra passenger side. Fits perfect. I like it when a plan comes together...
  13. 100% Matt
    100% Matt
    Diggin this build!
  14. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    So got front to back figured out now pinion angle and side to side.
    Found 1 fender is 12 inches from the frame and other is 13.
    Starting to get frustrating
    brEad, kidcampbell71, Stogy and 2 others like this.
  15. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  16. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  17. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Brackets Set.
    Not bad for amateur self taught YouTube University.
  18. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    010E719D-B916-4577-8D87-62266D73A603.jpg 61854969460__B7E4AD61-0AE1-4C44-A149-56FE0A8A16BB.JPG
    Gas tank is back in.
    New fuel lines.
    And I had a little help with painting the 9”. I pay them in juice boxes.
    Plus an altitude adjustment to the front.
  19. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Flathead green Chevy....
    Will have chrome valve covers.
  20. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Did some polishing.
    Gonna run polished moon disc on all 4....
    brEad, kidcampbell71, Stogy and 5 others like this.
  21. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Filled some holes....
    brEad, Stogy, kidcampbell71 and 9 others like this.
  22. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Couple updates.
  23. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Hopefully last mock up......
    brEad, 35cab, Shadow Creek and 9 others like this.
  24. okiedokie
    okiedokie
    from Ok
    You filled the holes for your wiper motor bracket? What are your plans?
    loudbang, Stogy, Thor1 and 1 other person like this.
  25. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    No wipers. It’s California.....
    loudbang, Thor1 and Stogy like this.
  26. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Wiper motor
    :for sale:
  27. Stogy
    Stogy
    I'm in the Club...:D...I call it fair weather driving...you do miss out on some events but I've lived with it...2 cool projects on the go...awesome...
  28. Newport wipers work good or a Mighty wiper (I have 1 side in the '41 P/U).
  29. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Getting closer. Should fire up next month
    brEad, Kiwi 4d, Stogy and 4 others like this.
  30. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Not finished yet, but a start to new alt bracket.
    brEad, Stogy, loudbang and 3 others like this.
