Technical 1940 Ford 2 dr. sedan- door interchangeability
Discussion in 'The Hokey Ass Message Board' started by paul55, Jul 31, 2021.
  1. paul55
    paul55
    from michigan
    Need a driver's side door for a '40 tudor. Wondering what others may fit.
  2. Likely only a '39 Tudor, but there goes your vent window.
    chevy57dude likes this.
  3. alchemy
    alchemy
    The doors will interchange from 37-40, but there are a few peculiarities in a 40. Only the 40 has the vent window, or the outer door handle which fits in an oval hole. A 37 won't have any trim holes, but those are easily drilled.
    warbird1 likes this.
  4. My '40 has a '39 door on one side and a 40 door on the other... both with the 40 vent windows, so they can be interchanged.
  5. flatford39
    flatford39
    You can put a 39 Fordor door on it must you need to trim the top a little.
  6. joel
    joel
    fordor front doors work for coupes. tudor sedan is much wider.
    lothiandon1940 and stillrunners like this.
