Technical 1939 Mercury Build
Discussion in 'Traditional Customs' started by swissmike, Jun 28, 2015.
  1. swissmike
    swissmike
    Welded the inner door post structure solid.
    Then the outer..
  2. swissmike
    swissmike
    Before welding in the quarter patch panel, I decided to fix the wheel well. This way it will be solid on both sides when I weld in the panel.
    The patch has some crown so I used the plastic mallet on the sandbag and followed up with my new English wheel. It's the bench top Eastwood unit and it's nicely made and sturdy and doesn't take up a lot if space in the shop. The pic is out of order, but I wanted to show the finished patch.
    rodncustomdreams likes this.
  3. swissmike
    swissmike
    Making the corner piece from the quarter to the wheel well, by using a couple of inches cut off from the new quarter panel.
    By now the outer contour needs a little tweaking..
  4. swissmike
    swissmike
    Welded and trimmed
    The rotted panel behind the patch is cut out and the new piece is scribed from the back side with the correct outline.
    Welded in place.
    Ready to cut the quarter panel and install the new metal.
  5. Peanut 1959
    Peanut 1959
    I love seeing this kind of work. It is this kind of dedication that will keep your ride on the road long after others have fallen apart from neglect.
  6. swissmike
    swissmike
    Patch panel welded in. The casual observer might notice a second cut line half way through the panel. This is what happens if you start cutting a the wrong scribe line, followed by a sickening feeling in the stomach, ha...
    Now on to the wheel wells. The lower couple of inches, especially where the spot weld with the floor pan are, is rotted pretty badly, so patches are cut and get a flange with the bead roller.
  7. swissmike
    swissmike
    Welded in as well. All the patches are 18 Ga and the difference in thickness between the old metal and the patches makes it easy to burn through. I welded from the inside, where the surface was cleaner.
    The last 10" or so of the new patch will be cut off again as it is not wide enough to cover all the rot.
    After some more grinding and massaging. It came out ok. It will still need a little more attention, but good enough to move on.
  8. swissmike
    swissmike
    This is the rear corner, which needs complete replacement. It has a reverse curve to make it more interesting ...
    I think I will do a corner piece with maybe 1/2" legs similar to the wheel well again, then do the rear panel and only then go back and finish the inside of the wheel well. Project for next week.
    jakespeed63 likes this.
  9. Hansa1100
    Hansa1100
    from Norway
    Loving this thread, exactly the things I need to address on my own car. With the same tools...
    swissmike likes this.
  10. swissmike
    swissmike
    Corner piece made on shrinker and stretcher.
    Cutting out the rotted section after tacking the corner
    Shaping the replacement panel
    Tacked in place
  11. swissmike
    swissmike
    This piece had some rust where the trunk floor was spot welded, as well as where the bumper brackets hit as a result from the body settling over the frame due to the rusted out body mounts.
    There is quite a bit of lead, possibly from the factory.
    I made a paper template and shaped the flange for the bumper slot first, then tarted shaping the panel little by little.
    After I had the shape close, I tacked it on top and used a thin cut off wheel to cut through both layers
    Welded in. Still needs a little hammer and dolly work to get the flow just right.
  12. FlatJan
    FlatJan
    incredible.. tried myself some metal shaping and it's not as easy as you make it look.
    keep up the great work (weiter so)!!
  13. The 39 guy
    The 39 guy
    Excellent work as always! I like your one area at a time approach as you work your way around the car.
  14. swissmike
    swissmike
    Thanks! Doing one area at a time greatly reduces the risk ending up way off dimensionally when doing a complex part, without making fancy templates and bucks IMO.
  15. barry mazza
    barry mazza
    Well Mike have been watching your progress and I must say you are doing a remarkable job of it, really with out the use of heavy duty metal forming tools, using your head to devise ways to get the job done, I say you have really done a great job, your skill is really showing my friend and I hope you continue to make good progress as winter comes to us and things cool down in the garage...Barry
    rodncustomdreams and jakespeed63 like this.
  16. stinkity stoink
    stinkity stoink
    from new jersey
  17. barobert
    barobert
    Hallo Mike
    Das gseht würkläch guät us wi das hesch gmacht. Fahrsch im Septämber de scho mit äm Merc vor?
    Bis gly
    Nöru
  18. swissmike
    swissmike
    Thanks Barry, very much appreciated!
    Nöru: Geduld, das wird nu chli ga..
  19. swissmike
    swissmike
    Made some progress in the meantime and the second side went easier thanks to the templates I had and what I had learned.
    First was the toolbox, which had some small holes and rust from sitting water.
    I replaced the bottom a few inches into the curvature in the rear.
    I meant to save the front of the box, but ended up replacing it as well when I ripped off the seam trying to separate the panels.
    tomkelly88 and rodncustomdreams like this.
  20. swissmike
    swissmike
    Other corner..
    Tacking the replacement on top and cutting through both...
    I think this area was a factory spot weld which was recessed and filled with lead. It was mangled by the bumper irons when the body settled and I patched both sides.
  21. swissmike
    swissmike
    Back end is done...
    Moving on to A-pillar. Bottom is completely gone and I'm glad for the templates I made on the first side.
    Inner structure had to be built as well
    Forgot to take a pic from the outside after I was done.
  22. swissmike
    swissmike
    Bottom of B post. This took multiple individual 90 degree profile pieces shaped with shrinker and stretcher, then welded together. I usually try not to weld along corner edges, but made an exception and welded from both sides before grinding.
    Finished, ready for the replacement quarter panel once I replace the rear edge by the fender.
  23. Loving all your progress. As soon as the smoke clears, I will take a ride down. Will bring some coffee from IKEA :)
  24. swissmike
    swissmike
    One more from the finished cowl area. Still needs the bottom caged fender nut welded in.
  25. MIKE STEWART
    MIKE STEWART
    nice info - thanks for posting!
    36 ROKIT and swissmike like this.
  26. Just found this, and need to do most of the same, with much less skills! Swissmike, how are you welding this? I've got an old mig welder, but I don't know what's available, nowadays! Everything you've done looks great...thanks for sharing!
  27. swissmike
    swissmike
    Everything is MIG welded. I have a 220v Hobart Handler, but even a 110 unit will do for sheet metal and most fabrication on a car. I use .023" wire for sheet metal (18 gauge steel for all body and floor panels). Ford used 19 gauge, but it's hard to get except special order at most metal supply places. 18 is more forgiving to work with than 20, which is too flimsy IMO. Just start with simple parts and keep practicing.
    1959Nomad likes this.
  28. Bruce A Lyke
    Bruce A Lyke
  29. swissmike
    swissmike
    I replaced the corner edge on the left first, then cut the previously made panel to fit. I do it in several steps, starting with one edge, then overlaying again, tacking if necessary, then moving on the the next edge. With every edge the panel will fit better and result in a better fit.
    I use the thin 3/64" cut off wheels after tacking if I feel I don't have enough gap between the panels.
    Ron Funkhouser and jakespeed63 like this.
  30. CURSED GEARS
    CURSED GEARS
    Love this thread. If I had a fifth of your talent, I would be 100 percent better! Keep it up, good stuff.
