Technical 1939 chevy sedan wiper arms to the vacuum motor lenght
Discussion in 'The Hokey Ass Message Board' started by Ornery37, Oct 26, 2021.
  1. Ornery37
    Ornery37
    from Texas
    Hi, I have a 39 chevy sedan and it is missing the arms that go from the wiper tower mechanisms to the vacuum motor. Was wondering if anyone has the measurement of both the arms? Thanks in advance.
  2. Shadow Creek
    Shadow Creek
    I’ll try to get to the shop tomorrow and measure for you
  3. Rusty J
    Rusty J
    Here you go: Long arm measures 18 7/16 total length, 17 7/16 center to center of shaft holes. Short arm measures 6" total bent length (5 7/8" measured length end to end with bends made) but must be bent up 1/2" from level on one side - so the measurements are: from wiper motor: 3 7/8 parallel to surface, bend up by 1/2" (measured length of rod to bend is 7/8" from break point to break point, and remaining (parallel to surface) length is 1 1/4"
    wiper motor holes measure 1/4" and are drilled 1/4" from center of hole to edge, wiper transmission (chrome post) is 1/8" hole and again drilled 1/4" from end. Rod material width is 7/16" and 1/8" thick
    Shadow Creek likes this.
  4. Ornery37
    Ornery37
    from Texas
    Thank you so much.
