Pick up only, located in the Chino/Ontario area. '39 3 speed trans that has had the outside cleaned, degreased and rubbed down with a steel brush wheel. Inside cleaned out as well. Transmission has had a rebuild kit installed. 29 tooth gear cluster with normal wear on the teeth but in overall good condition. Gears move freely with fresh rebuild. I have a shifter tower for it as well along with the inspection plate cover. If I have time this week I will paint the trans in Ford green but that will not affect the price, just the looks. What you see is what you get and I can post more pics if needed. Buyer assumes all responsibility at time of purchase.
