1937 Ford coupe with 1938 Deluxe front sheet metal. This is an old hot rod build with stock ford frame with a 1956 Chevy front clip grafted on. 1967 Nova posi rear with 3:08 gears mounted with Chassis Engineering parallel leaf spring kit. 1967 Chevy 283 rebuilt with about 20,000 miles on it, with new Edelbrock Performer manifold and Edelbrock 600 cfm carb. Turbo 350 tranny, Lokar shifter, and new driveshaft. Tons of new parts including HEI distributor, 100 amp 1 wire alternator, mini starter, aluminum radiator, all new brakes,cylinders, hoses, lines, hardware, cables, residual valves, shocks, front end completely rebuilt with springs, ball joints, tie rod end, drag link, control arm bushings,etc. All new glass window felts and rubber gaskets, Rebel wiring 9+3 harness, Speedway steering column, new Stewart Warner gauges oil,water,volts,fuel, SW speedo, new headlight sealed beam conversion kit, new poly gas tank and SW sender, 5 new Remington bias wide white walls on steels wheels, fiberglass running boards, louvered hood, all new floors front to back , all new EMS replacement body panels plus much more. Clear Mass. title in my name. Car runs and all lights including directionals work. Needs interior, minor body work and paint and some TLC. Call Bob 413-537-2934.
