1936 Roadster build (from a 4 door, and 5 window)
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Mar 19, 2010.
  1. milkweed
    milkweed
    from SLC UT
    Im in for a cowl top and i will be down to do whatever let me know...
  2. brigrat
    brigrat
    from Wa.St.
    This will not be an exact replica of a '36 Ford roadster, not even close, that's why I am having it done this way. Would rather have steel where wood was and will be taking "styling liberty's" that wouldn't be taken on a nice stock roadster. Still kicking around ideas but here's one or 2........
    To me "Coupster" dosen't ring to well, I think Chris will give it a hole new meaning with this build ........................
  3. Those look great! I´d be doing the same thing I should think - this isn´t a restoration after all. And it´s certainly the only way I´d ever afford a 36 Roadster!:cool:
  4. flynbrian48
    flynbrian48
    I kinda like version #2. For some reason the skirted one just doesn't have "the look". Maybe 'cause we're used to seeing skirted '36 down in the rear...
    Brian
  5. flynbrian48
    flynbrian48
    LOL, my avitar wasn't any more than that, and I want to do a lakester styled one, so that's all I think I'd need!
  6. brigrat
    brigrat
    from Wa.St.
    Guess it's already been done!
      49.1 KB
      64.7 KB
  7. KillerKustom
    KillerKustom
    Please give us updates as the work goes on.
  8. Ditto on #2, "the look" says it all. The rake is perfect.
    Johnnie.
  9. flynbrian48
    flynbrian48
    Yes, but your's could be BETTER (read: not satain black)! :D
    There's something not quite with the w/s posts too...
    Brian
  10. Not MG enough for you Bri...?:D
  11. Subscribed, as well......
  12. harrington
    harrington
    from Indiana
    Chris, I can't wait to see how it turns out. I must say you do some fantastic metal work.
  13. Django
    Django
    from Chicago
    Looking forward to the progress....
  14. flynbrian48
    flynbrian48
    LOL, well, that wasn't what I intially meant, but now that you point it out...:p
    What I noticed was the rounded tops where there should be a hard corner as a cabriolet would have. That just screams "I'm a coupe with the top cut off" to me. Rolling the door tops, modifying the dash as BigRats plan is, with a set of roadster posts will look MUCH better, IMHO.:D
    Or, an MGB w/s frame would look nice too...;)
    Brian
  15. Salt Flats Speed Shop
    from Utah
    Today was the official main start!!! Got the cowl bolted and the doors hung. Ive started to push out the rear door posts to line up with the doors. Ill start at the front of the door and get the gap the way I like it. Then ill adjust the cowl until the rear gap matches the front.
  16. 29 bones
    29 bones
    from so cal
    I like......
    cant wait to see more....
    Brian
  17. elcamino65
    elcamino65
    from washington
    Looks nice.
    When is it comming back here?
    How much for that baby hemi
    cordell
  18. Salt Flats Speed Shop
    from Utah
    Well after a long couple days I got the roadster all finished and got it in primer. Man that took a long time to do :)
    Just kidding ya, its my buddies original roadster that I'm using for all my patterns. I tried the whole waving my wand trick to finish it, but looks like I'll have to do it the old fashion way....one step at a time.
  19. SLCHC-CHIEF
    SLCHC-CHIEF
    from S.L.U.T
    Man this is going to be sweet!!
  20. fitzee
    fitzee
    Going to keep a close eye to this.
  21. KAdams1476
    KAdams1476
    from Midwest
    Judging by the time between your last post and this one I figured you had an alchemist helping you out with this one! If your plans are to make something similar then I say Godspeed. From what I've seen from a few other posts praising your work, this thing should turn out sharp.
    (BTW, I'm a new poster-never bothered to get a username-but I've been into Jalopy Journal and a few other sites for quite awhile and your reputation preceeds you. Good luck with the '36.):)
  22. 32ford5
    32ford5
    from Australia
    That was funny! I actually thought "WTF?!"
  23. KillerKustom
    KillerKustom
    I thought holy crap, you put aged wood in and everything. Hehehe
  24. UnsettledParadox
    UnsettledParadox
    too frikkin cool!!!
  25. Mr48chev
    Subscribed and this one might be a HAMB thread vehicle that I will actually have a real chance of seeing when it's finished.
  26. Salt Flats Speed Shop
    from Utah
    Glad you all liked that :)
    So Im starting on the cowl now. Luckly enough the raised section for the windshield to lay on on the roadster is the exact same as that first raised section on the sedan cowl. All I had to do was hammer it back down. Hope that makes sense. Now I'm just making the new piece that rounds into the dash and into the doors.
  27. flynbrian48
    flynbrian48
    Huh. Almost makes me want to redo the cowl of the Fordillac. Good idea.
  28. fab32
    fab32
    I think we've got another masterpiece in the works. I can't think of anything I like to see evolve more than quality metal work.
    Frank
  29. brigrat
    brigrat
    from Wa.St.
    I like the words "All I have to do", makes it sound "cheaper to do" ! Really guy's your seeing it before I do ....................................
  30. Roadsir
    Roadsir
    Two things impress me alot:
    1. It's awesome you are equally or maybe even more excited about the build as the owner. That in itself should make you both happy.
    2. How quickly you get after it. I'm sure you're probably thinking about it 24-7 but it appears your damn productive.
