One of the old timers at the shop has a real nice 1936 Ford. He put juice brakes on it and it now has what look like F100 steelies that use a hubcap that mount outside the bolt circle. Aside from changing rims, what hub caps are available that will look nice on an otherwise stock looking vehicle? I'm not sure what rear end he said he had, but I thought it was a late 40's rear end. The axle stuck out about 4-5" from the drum and it looks hubcap with a larger dome would be better.
not sure which rims he is using. if they have the bumps to the inside , `40-`48 car and up to `56 pickup will fit. i like the `42 the best , few people use them if the bumps are on the outside , Mercury pie pan caps
He needs the caps that mount on the outside. I guess, when I say outside, I mean like the wheel in the bottom of the photo. He wants to run trim rings but needs a hubcap to fit. The Dog Dish fit inside the bolt circle.
