1936 Ford Truck DRIVE TRAIN 401 BUICK NAILHEAD. APPROXIMATELY 2,000 MILES. (FRESH BUILD, 2K ON REBUILD. REBULT BY O.C CARS IN SOUTHERN CALIFORNIA TRW FLAT TOP PISTONS 671 BLOWER BUILT BY HAMPTON BLOWERS IN DOWNEY 6 CARB WIEAND BLOWER TOP MANIFOLD 6 STROMBERG BIG 97 TWO BARREL CARBS CUSTOM MACHINED PROGRESSIVE LINKAGE 6 CUSTOM AIR SCOOPS WITH FILTERS 6 OUTLET FUEL BLOCK GREEN FUEL LINE CUSTOM STRAIGHT PIPE HEADERS POLISHED FINNED OFFENHAUSER VALVE COVERS POLISHED FINNED OIL PAN CARTER ELECTRIC FUEL PUMP MANUAL FUEL PRESSURE REGULATOR CHROME POWER GEN GENERATOR CLOTH SPARK PLUG WIRES PERTONIXS ELECTRONIC IGNITION & FLAME THROWER COIL ST400 AUTOMATIC TRANSMISSION EXTERNAL TRANS COOLER STOCK GM REAR END OUT OF A 64 BUICK RIVERA WITH 3.08 GEARS COOLING CUSTOM BUILT ALUMINUM RADIATOR. BUILT BY MATTSONS IN STATON, CA ELECTRIC FAN SET UP KEEPS MOTOR RUNNING COOL CHASSIS CUSTOM BUILT FRAME STOCK 1930 FORD TRUCK STRAIGHT AXLE 28' REVERSE EYE SUPER SLIDER LEAF SPRING BY POSIES QA1 COILOVERS BILSTEIN CHROME FRONT SHOCKS REAR BRAKES - 1964 BUICK RIVERA DRUMS FRONT BRAKES - 1940 HUBS ON BUICK DRUMS. BACKED WITH RARE WILSON BACKING PLATES PROPORTIONING VALVE, RESIDUAL VALVES AND PRESSURE SWITCH REAR RIMS - 16' 40's FORD REVERSE CHROME SMOOTHIES W/4 INCH BACKING SPACE FRONT RIMS - 16' 40 FORD CHROME SMOOTHIES FRONT TIRES - FIRESTONE 550/15X4X 3.5' REAR TIRES - 16X10' HURST CHEATER PIE CRUST SLICKS BODY/INTERIOR FEATURES 1936 FORD TRUCK CAB W/ 5' CHOP 1936 FORD GRILL WITH CUSTOM MADE CHROME INSERT SHORTENED MODEL T TRUCK BED ORIGINAL GUIDE 682-C HEADLIGHTS WITH TURN MARKER THAT LIGHT UP GRREN SHAVED DOOR HANDLES WITH MINI BEAR CLAW LATCHES STEWARD WARNER WINGED GAUGES INTERIOR - COMPLETED 1 YEAR AGO. *BENCH SEAT THAT TILTS UP WITH SHORAGE. *ISLANDER BRILLIANT WHITE, LIGHT GREEN ZODIAC INSERTS WITH SLIVER PIPING. *CARPET IS SILVER BASE WITH A BLACK CARPET W/SILVER TINSEL LOOP TOP (VERY COOL) *SILVER SEAT BELTS CUSTOM MADE GREEN TINT LEXAN SIDE AND REAR WINDOWS VINTAGE SUPERIOR GREEN FLAKE STEERING WHEEL MISC CUSTOM STEERING COLUMN 1936 CALIFORNIA LICENSE PLATES 1966 VOLKSWAGON STEERING BOX OPTIMA BATTERY LOCATED UNDER BED VINTAGE OIL CAN AS OVERFLOW TANK 15 GALLON SPUN ALUMINUM FUEL TANK WITH CHROME BRAKETS 21 CIRCUIT GM MINI FUSE PANEL & HARNESS BY "ITS A SNAP" LOKAR 23' SWAN NECK NOTES SPEEDOMETER NOT WORKING FOR SOME REASON DRIVERS DOOR NEEDS A LITTLE EXTRA PULL WHEN CLOSING NO WINDSHIELD WIPERS OCCATIONAL LIKES A FEW DROPS OF TRANNY FLUID SOME DAMANGE TO THE LOWER RADIATOR FINNES. DOES NOT EFFECT COOLING SMALL RUB MARK ON FUEL TAKE. CAN BE POLISHED OUT THIS LITTLE PICK UP REALLY GETS UP A GOES!! RUNS, STOPS, AND HAULS A$$. Asking $36,000
