1936 Rebuilt LB shortblock. Cleaned , Maged, decked, and repaired at Schwams bearings in pa. Lifter bosses drilled for adj lifters, New lifters, springs, valves as needed, new cam gear and bearings. New grant rings .030 over. No worries with this block on crack issues. The work has been done. Could use a .o60 over bore to make it good. Also new fuel pump push rod installed. Also for sale are 1933 alum factory heads. Machined .050 . Other parts for sale as well. Don 717-517-0204 pa Sold. Sold Sold
