Auctions
1936 Ford Chassis
Discussion in 'Parts For Sale' started by MR. FORD, Apr 23, 2018.
  1. MR. FORD
    MR. FORD
    from Austin, TX
    City: Austin
    State: TEXAS!
    Price: 3000
    1936 Ford Chassis, could also work for most 35-40 cars
    Almost a roller, includes:
    1936 frame, fully boxed, stock front crossmember, rear has been set up for chassis eng. parallel leaf springs. Includes new posies springs, chassis eng. rear shock kit, shocks, ubolts. Two tubular crossmembers added for strength. At one time was C notched, but has been brought back to stock, with the notches removed. Has all its body boxes and rear body mounts. POR 15 inside the rails and boxing plates. It's straight and nice. Been sitting for a few years, will need some surface clean up here and there. All the suspension is new, never run, just been sitting in storage.
    Front end:
    1939 axle and unsplit wishbone, chassis eng. 1" lower new front spring, 37-41 front spindles, new kingpins, '39 brakes, chassis eng. sway bar kit never installed, flat top perches, chassis eng. shackles/lower shock mounts.
    Rear end:
    1965/66 Ford Mustang 8", 2.90 gears, rebuilt and never run, stock axles, 5x4.5 pattern, new lug studs, new bearings and seals, new flex line, several pre bent, usable brake lines, backing plates and bolts.
    Hoping to sell as lot, pick up Austin TX.
    Lasallefever likes this.
  2. MR. FORD
    MR. FORD
    from Austin, TX
  3. MR. FORD
    MR. FORD
    from Austin, TX
