Auctions
1935 Ford Three Window Coupe - Price Change
Discussion in 'Cars For Sale' started by Blown35, Jan 22, 2022.
  1. Blown35
    Blown35
    City: Livonia
    State: New York
    Price: 255,000
    • This remarkable, well sorted 1935 Ford Three Window Coupe was custom designed and built by the nationally recognized East Coast Hot Rod Garage, Denton Maryland. Having been selected as a “top five contender” for the prestigious Street Rod Of-The-Year sponsored by Classic Instruments, it was a cover car and featured Coupe showcased in Rodders Journal # 79. (Cover picture courtesy of Rodders Journal)
      Powerfully built showcasing a Ford 482 cid FE 580+ hp backed by a Tremec TKO-600 5 speed, spinning a 4:11 posi housed in a chromed Ford 9 inch differential. It boasts a unique unibody construction to handle the 610 ft. lbs. torque by integrating a custom Precision Hot Rods & Fabrications fully boxed 35 style frame to floor-pans and body for a super rigid welded single unit. While barely noticeable to the overall look, the cowl was stretched by three inches for all important body proportions, interior room and comfort. While nearly undetectable, it has a perfectly integrated 39 ford stainless trim and “one-off” 1939 Ford style trunk lid graced by a 1940 Ford trunk handle. The ride is enhanced by a smooth blend of power rack & pinion steering, power disc / finned aluminum brakes, air conditioning, a killer sound system and much more! Can provide 100+ pictures of the complete build in detail to potential buyers.
      Body
      Original all steel 1935 Ford Three Window Coupe
      Unique uni-body construction
      Cowl stretched three inches
      “One-off” 39 Ford style trunk
      1939 Ford modified stainless side moldings
      Nerf bars F&R custom
      Roof filled with custom insert
      Fabricated cowl, rear wheel tubs, front inner fenders, louvered belly pan
      Hood tops original with custom side panels - louvered
      Fenders originals modified for correct proportions
      Grille shell sectioned 2.5 inches with fabricated Alumicarft insert
      Headlights 1936 Ford with shortened stanchions
      Taillights original stock 35 Ford / modified
      Paint
      PPG 2-stage “Raven Black”
      Interior
      1939 Ford dashboard with custom sub-dash
      Custom bucket seats
      Hurst shifter
      Custom fabricated pedal set
      Classic Instruments with original period Sun Tach
      Mullins 3-spoke steering wheel – super rare
      Borgeson steering drop
      Merlot/Maroon leather
      Merlot/Maroon wool carpet
      Chrome roll bar and window garnish
      Chassis
      Precision Fabrication 35-40 style frame rails narrowed F&R
      Wheelbase extended to 115 inches
      Art Morrison rear cross member
      Power rack & pinion with Unisteer box
      Front Suspension
      TCI A-arms and Spindles
      RiseTech coilovers
      Custom sway bar
      Rear Suspension
      Ford 9 inch, narrowed to 48 inches, chromed housing with chromed center section
      4:11 Posi
      31 spline axles
      RideTech coilovers
      4-Bar link system, chromed
      Panard bar, chromed
      Sway bar, special fabricated
      Brakes
      Wilwood dual-reservoir master cylinder
      Front - Wilwood 12 inch rotors with 4-piston calipers
      Rear - Buick style 11 inch finned aluminum / John’s Industries
      Wheels/Tires
      Front – 16X7 American Rebel Spirits with 205X60X16 Goodyear radials
      Rear – 16X11 ET III Fueler aluminum with 31X11X16 Hoosier radials
      DriveTrain (Blair Patrick Enterprises)
      482 cid Ford FE V8 – 580+ hp / 610 ft. lbs torque
      Bear Block Motors cast iron block bored .030 over
      Scat forged stoker crank
      Scat connecting rods
      Mahle forged pistons
      Comp Cams hydraulic roller camshaft and lifters
      Canton oil pan – 8 quart
      Edelbrock aluminum heads
      REV stainless valves, Manley valve springs
      Edelbrock 2X4 barrel aluminum intake manifold
      Moon finned polished aluminum valve covers
      Moon spark plug covers and air cleaner
      ARP fastener hardware
      MSD 6AL ignition
      Fabricated headers
      Flowmaster 2-chamber mufflers
      Transmission
      Tremec TKO-600 manual 5 speed
      McLeod dual disc / dual face clutch & flywheel
      McLeod hydraulic throw-out bearing
      Quick Time bell housing
      Driveshaft – polished aluminum
      Misc
      Walker Super Cooler radiator
      Wiring harness – American Autowire
      Jon Wright Custom Chrome through-out
      Stainless steel 3 inch fabricated exhaust system
      Actual build cost far exceeds asking price
    • Price: $285,000 Negotiable
  2. Blown35
    Blown35
    BTT
    Thanks all for some nice offers - so far not quite there yet - would welcome additional players to consider purchase.
  3. Blown35
    Blown35
    Spring is here and time to get yourself in this Coupe!
    Offers are getting better but trades as part of the deal are not of interest. I'm coming off the initial $285K asking and willing to consider cash deal north of $225K. As you can imagine, the build cost of this machine is far far in excess of that amount.
    billg51 likes this.
