*****SOLD****** This 1935 Ford 1/2 Ton Pickup truck was removed from a Fresno, Ca home where it was stored in a garage since the early 70's. The truck has a Ford Flathead V8, with 59AB head, and a Lincoln Zephyr carb. The engine does turn over, and fired up with some fuel in the carb. The electrical system is still 6 volt. Overall the truck is fairly complete. The truck will need metal and body work throughout. There is rusted areas in the bed, fenders, and cab. The fuel tank will need to be replaced. The frame has been outfitted with juice brakes which will need to be gone thru. The rear axle appears to be stock. The front window will need to be replaced, and the side glass is also missing. There is a tailgate in the bed as well. Truck also has a banjo wheel out of a car. Please let me know if you have more questions. Have clear title in my name. The California DMV put 1939 on the title instead of 1935 which should be fairly easy to fix or not for the new owner. I can work with overseas buyers as well, and provide a list of transportation carriers if necessary. Currently listed on an AUCTION site. $9k obo
