Customs 1935 Ford 5 Window Coupe Sheet Metal Question
Discussion in 'The Hokey Ass Message Board' started by BanjoBoy, Dec 27, 2016.
  1. BanjoBoy
    BanjoBoy
    Hello there
    I have aquired a 1935 Ford 5 Window coupe Running and Driving
    The Body has been channeled the width of the frame and It does not have front / rear fenders / running boards/ hood or grille/
    it has a dropped front axle in front
    here are my questions and concerns
    1) would the stock sheet metal bolt on and clear with the current channel (width of the frame)
    2) I understand that 1936 parts would work on a 35 so long as i stick to ALL 35 parts... is this correct?
    3) i want to make it a tail dragger and bring the front up / would this help in clearing the sheet metal?
    well thats just about it
    any help would be appreciated
    Im sure someone here with a 1935 / 1936 would be able to provide first hand knowledge
    thanks
    jason
    i posted this on the Hamb /
    I posted wanted ads here and the hamb
    have trade or cash for correct parts IF this will work
    thanks
    jason
  2. You sure its channeled? in 35 the body fits over the frame from the factory. you might just have a car that needs all the fenders and such...
  3. big*b
    big*b
    Front fenders and running boards bolt to tthe frame. If you want to run fenders and have the hood line up then you will have to raise the body up unless you get creative with the mounts. Doubt lifting the front of the body will help because of the running boards. I am currently unchanneling my 35 coupe.
    Sent from my SGH-I337M using The H.A.M.B. mobile app
  4. BanjoBoy
    BanjoBoy
  5. BanjoBoy
    BanjoBoy
  6. BanjoBoy
    BanjoBoy
    Body chanelled to width of frame
  7. BanjoBoy
    BanjoBoy
  8. Johnboy34
    Johnboy34
    from Seattle,Wa
    To answer your questions;
    1. NO
    2. You use all 35 fenders, grill, hood, and all related parts or all 36 fenders, grill, hood, and all related parts.
    3. NO
    You could maybe add hood tops?
  9. BanjoBoy
    BanjoBoy
  10. BanjoBoy
    BanjoBoy
    Does anyone know of a 1935/36 Coupe that is channeled width of frame but still retains stock fenders / Running boards/ Hood/Grille?
    I appreciate the help
  11. brigrat
    brigrat
    from Wa.St.
    You must not believe Johnboy 34?
    If frame is usable buy a floor and Firewall (or add to bottom of Firewall) and put body where it belongs THAN build to suit.......................................
  12. BanjoBoy
    BanjoBoy
    Excellent
    I appreciate the advice
    Im gonna focus on getting the sheet metal parts
    mock everything up
    and let the car help line things up
  13. brigrat
    brigrat
    from Wa.St.
    This will be interesting considering front and rear fenders bolt to running boards and running boards bolt to side of frame where your body is now. If you get passed that than you can tackle the front sheet metal & radiator area where ALL your front sheet metal gaps line up not to mention you will need a shorter radiator, shorter front fender/headlight brackets, etc. etc.................................................
  14. BanjoBoy
    BanjoBoy
    Now this is what i was looking for
    Thank You
  15. brigrat
    brigrat
    from Wa.St.
    If you really like the info and not being facetious, there's a little "like button" to the right! I need all I can get! There like old Green Stamps, you can trade them in at the HAMB store for valuable HAMB gifts!
  16. Johnboy34
    Johnboy34
    from Seattle,Wa
    And that's if the fenders aren't sitting on the tires.
    brigrat likes this.
  17. brigrat
    brigrat
    from Wa.St.
    And bottom of the grill dragging the Earth....................................
    Johnboy34 likes this.
  18. big*b
    big*b
    First photo gives you a rough idea how the front fenders and running boards attach in the stock location.
    Second photo is a stock floor sitting in its proper locations on the stock frame.
    clunker, BanjoBoy and Johnboy34 like this.
  19. flynbrian48
    flynbrian48
    I dunno, if you like it channeled and fender-less, leave it alone (although some may argue that fat fendered body wants fenders), and be happy. If you want fenders, it might be better from a $$ standpoint, and time, to sell it and buy a non channeled car and build it. Quicker, less money, less hassle. Not to say you couldn't un-channel it, but, man, it could turn into a headache.
    BanjoBoy likes this.
  20. krgdowdall
    krgdowdall
    from Alberta
    Are you sure it is a 35 ? The X stamping on the sides of the cowl, just ahead of the doors, generally indicates a 36 body. The 35 was smooth. Not sure this was all the bodies or may have been a mid year production change.
  21. It wouldn't be too hard to block the body up a couple inches if you had too.
  22. BanjoBoy
    BanjoBoy
    Interesting
    Anybody know if this is a 35 or 36??
  23. BanjoBoy
    BanjoBoy
    Love the idea
    Anyone opposed to this possible solution?
  24. brigrat
    brigrat
    from Wa.St.
    Buying all the front end pieces is going to cost a pretty penny even if you went glass front fenders over metal ones.
    Hood top and sides and all hardware
    Grill
    Grill under garments
    Radiator
    All front brackets to mount front sheet metal
    2 inner fender panels
    If you 36 you have 2 horn panels between fender and grill
    Headlights & stands
    A few more things I have forgotten
    And that's just the front, in the rear you need rear fenders
    Inner quarter panels
    Tail lights & stands
    All sort of little brackets
    Running boards
    Point is your gonna have some serious coin in making it a Custom '36, it will be a cobbled mess if body is not mounted on frame properly not to mention the floor space that will be missing. It's hard enough getting things to line up properly mounted let alone "lifted". Do a search on E-Bay or ask around for a full floor and do it rite. It will be worth more to you and others done the rite way. JMO
  25. My '35 has the X stampings and I know of others that also have them.
  26. Couple things I think were not mentioned so far. Hard to tell; but it looks like your motor may be mounted a little forward to play nice with stock radiator location. It has to be pretty tight to the firewall on a '35. You may have to undo some of the current lowering, especially the front. With a dropped axle I have pretty minimum grille to ground clearance, no way it could be dropped the amount of your channel. Like any of these projects, it could be done; but it's up to you to figure out if it is worthwhile and if you have the skill to pull it off. Here's some more pictures of the inner fender panel and grille fit to frame along with some engine to firewall shots to help you consider those aspects of the project.
    Atwater Mike and BanjoBoy like this.
  27. All 36 bodies have three hood rubbers on side cowl do they not?
  28. Here's one that is partially fendered and chanelled if that helps.
    RICH B likes this.
  29. Rusty O'Toole
    Rusty O'Toole
    I happen to like channeled cars. Have not seen a channeled 36 before but most Fords of the 30s and 40s have been channeled.
    If you want the full fendered look you will have to modify the front end and rear fenders to fit.
    Another idea is to go full hot rod, make your own grille and fenders. This would be easier and cheaper than modifying stock parts.
    Rear fenders will need to be raised and fitted to the body. You could use any suitable late 30s fenders as they will have to be modified.
    For the front you could do something like this.
    or this
    or this
