Hot Rods 1934 Ford tailight position
Discussion in 'The Hokey Ass Message Board' started by WiredSpider, Apr 4, 2020.
  1. WiredSpider
    WiredSpider
    I need some information
    I,m working on a friends 34 Ford coupe
    I need measurements for the stock Taillight brackets so I can mount stock taillights.
    How far from the body?
    How far up from the bottom of the fender?
    Thanks
  2. Johnboy34
    Johnboy34
    from Seattle,Wa
    Do you have these? they bolt under the fender and will locate the stand for you.
    they are in Bob Drakes catalog.
    Taillight Brace; fits 1933-34 Car
    Item Number:
    40-13463
    Your Price:
    $30.00 EA
    In Stock
    Qty:
    ShareFacebookTwitterEmail
    Reinforces taillight brackets to fenders. These braces are a must to keep fender and taillight stand rigid. Painted black. What’s hidden beneath your rear fenders is very important. These braces were on your Ford when it was new, and for a darn good reason. Especially for cars with rumble seats, these braces offer the necessary support and shielding to protect your fenders and wiring from damage. Replace your corroded, weakened original units with fresh new braces. Bolts to the frame and provides needed support to the fender and taillight while also keeping the taillight wiring shielded and in place. RH or LH.
  3. WiredSpider
    WiredSpider
    Thanks but it has glass fenders and the fenderwells are heavily modified
    I do have those brackets thou
  4. 31aford
    31aford
    from az
    I have sedan fenders. They should be the same. If you want measurements let me know
  5. WiredSpider
    WiredSpider
    Yes,I do
  6. 31aford
    31aford
    from az
  7. WiredSpider
    WiredSpider
    31aFORD Thanks for the help.
    The measurement from the edge of the fender,is that inside or outside edge?
    Thanks again
  8. 31aford
    31aford
    from az
    The measurement is from the inside edge of the fender. The bottom hole is measured from the bottom edge of the fender
