it's finally for sale. my "half glass coupe " 1934 3 window. 1966 corvette 350hp 327 sbc, all rebuilt, tri power w/3 97's. t5 trans , 3.54 gear 34 banjo rear. 46 brakes. f1 steering. this is on a full original very nice chassis, factory 34 front axle , reverse eye front spring , ladder bar rear using the original 34 radius rods. the shocks. McCloud hydraulic slave cylinder, wilwood master for clutch , early ford brake master. custom made fuel tank, gm sender. stewart warner wings, 40 ford steering wheel. much much more. this is a fiber glass car, all oak inner structure with steel backing, crank out windshield, original cowl vent, original wind up windows, bear claw dual stage door latches. repop outter door handles, external door hinges .49 ford trunk hinges, salt flat style push bumper, 40 ford wheels, 4.50x16 front, 7.00x16 rear. all new window glass, new windsheild and frame. caravan seat and grey carpet... 12 circuit wiring harness, electric fuel pump, 4 position headlight switch , turn signals , guide headlights converted to blinkers/park lamp up top. 37 ford tail lights with so-cal stands, real 34 hood and side panels,repop fender aprons, real 34 dash , real 34 grill. aluminum rad from superior radiator.. new gear drive starter and new 1 wire alt. Mallory dual point dizzy, hotrod works open drive kit, custom made driveshaft. this car is a real head turner. runs top notch. very Lopey cam but still has good street manners. never runs warm, dual straight pipes ,... this car has been driven about 1000 miles since finished up. it's still a project needing some adjustments and things finished up. it is 1 of a kind that's for sure. lots of hours in making this car respectable for a glass car. decided to let it go. I've decided I want to build a 32... no tire kickers . I know what it costs to build a 34.. even a glass one . especially with the looks that this car has. I'll upload some photos .there is no interior , some of the photos may be from the building stages.. clean 34 title in my name contact Ben Haag 724-301-4736 or you can email me. [email protected]
